Front Bumper issues
Front Bumper issues
It seems this time ever year i am enjoying spirited runs on twisty roads only to return and find a plethora of
unsightly random marks adorning the front bumper and splitter. Any one else experiencing this phenomena?
Received 5,388 Likes
Couple things will help removal.
RejeX Wax. Very good. Easy on. Easy off. Relatively cheap.
Bug Barricade from Griots. Very helpful over your sealant wax.
Ceramic Coating. Best. Now I no longer use the two above.
When you say "random marks" I am assuming you mean bugs.
After a long drive they are stuck like glue. With ceramic your telling me they just wipe off?
I use a product called BAAM. It was originally designed for the aviation industry. If you think car's bumpers attract bugs, you should see what an aircrafts leading wing edge looks like after a night flight. Apply it before the spirited drive and removal become easy.
For washing, and removing, dwell time is the key. So, a foam cannon helps, but a spray bottle with about 75% water and 25% car soap works great. Just keep spritzing the front bumper with the soap/water solution till the bugs start to dissolve, they are mostly carbohydrates and a little protein, so very water soluble. Use the entire 32 ounce bottle.
I don't like using dedicated "Bug Removers" because they are too harsh, and remove your simple wax/sealant (probably not a nano ceramic coating) defeating the purpose of a quality coating, plus, they are expensive.
I have my car coated with Gyeon Can Coat and after every other wash use Gyeon Wet Coat as a final rinse. The bugs that are plastered to the front bumper mostly all come off during the initial spray of the car before washing. A good base and there are no issues.
Road trip about 3 weeks ago:
or use Mothers R3, great on bugs and race rubber.
