991.2 rear view mirror in 991.1
Hi all,
I've tried various search terms and I cannot seem to turn anything up. Has anyone ever installed the 991.2 rear view mirror in a 991.1? It obviously is possible as Suncoast sells the part: https://www.suncoastparts.com/product/9X1RVMIRROR.html
I'd like to do this, but I'm not certain on how difficult it is. For those that have installed a radar detector, how much work might be involved after you've pried the outer plastic bits off and have exposed the mirror arm? I can't imagine it's too tricky past that step.
I installed a radar detector in my .2 GTS with a Blend Mount Mirror tap to power. I thought that was quite simple and I think you will find that swapping mirrors is very simple, assuming you have some mechanical aptitude. I think you should just take the plastic covers off and take a look at it to determine whether or not you think you can do it. I think you will find it pretty easy. If for some reason you don't, just take the car to a stereo shop. They'll be able to do it for you.
Rocky Mountain High
What’s the appeal? Is it the bigger size, or do you prefer the look of the newer mirror? I actually like the unique shape of the older mirror.
Hi all,
The new mirror might be a total placebo effect. I might just need to sit in a new 911 before I order the part.
The old mirror does cut off quite a bit of area creating blind spots which are reduced with the new mirror. That was my #1 reason to change it and to my eye it does make a difference.
I am also replacing the driver side mirror with the aspherical glass to reduce the blind spot especially in the cabriolet.
But I also like having no bezels - seems to be the trend these days. The orange light is gone, it is a dimmer green light now at the bottom. Overall very happy to have an updated look in my cabin. Goes well with my 991.2 steering wheel!
