Closure on My PCCB/Wheel Clearance Problem
#61
Bummer. It happened to my 2019 911 C2 GTS with PCCB today. I driver the car as often as I can and a gravel road did it today. Sigh.
#62
Well I guess I'm lucky because after 25k miles on the car I never had this happen. However yesterday pulling out of parking lot I heard metal grind to find a rock had wedged itself in between the PCCB caliber causing scratches on the caliper and wheel...I revered and it fell out. I inspected all 4 wheels and found they all had some level of marking from this happening in the past. The clearance in the front is ridiculously small at like 1/4 inch...can't even stick my finger in between.
Seems like this is inevitable and now that there are scratches maybe I should just 'give up?' Seems like its bound to happen again even if wheels/caliper was replaced and I don't want aftermarket wheels.
#64
Received 5,388 Likes
Originally Posted by CCDD
Has this only been a problem with those that have PCCBs?
#65
I had 'rock sticks' in my S brake equipped 981 CS as well. Disconcerting the first time you hear it/fix it. Easy thereafter. I'll take the other 99.9% of the great driving/braking on the balance.
ß
ß
#66
My 2019 T with less than 500 miles on it. Both front wheels and calipers have scratch's. My T came with Michelin PS and what I think happens is at very slow speeds, 5 to 10 mph, at tight turns on a rock/stone graveled driveway the rocks get picked up by the semi gummy tires and then roll off with a tight turn onto the wheel barrel and end up getting jammed in between the caliper and wheel. I heard the sound of this happing the other day and took a look.
#67
Yep looks similar to mine...
Its disappointing, but I think there's nothing that can be done... its going to get more I'm sure. Seems like just accepting it is the only solution.
I agree its from low speeds... I went through plenty of gravel before and never had a problem. Its when I was in parking lot and took a hard right turn after slowly crawling.
#68
Only HRE P101 have the option for extra clearance or also the R101 LIGHTWEIGHT?
Any idea about BBS FI-R?
#69
I have had rocks rattle around in the wheels on my previous 991S with S brakes. *Didn’t look to see if they marked up the inside of the wheel, though, so I don’t know. *Made a hellacious racket.
#70
My new wheels provide about 1/2” of clearance. OEM is less than 1/4”, more like 0.20” at the tightest place. I have about 3k miles on the car now and not a scratch on calipers or wheels anywhere. I think it is the very lightweight pebbles that cause the problem. Where I live the rural roads that are a lot of fun to drive are tar and rock chip pavement. And I believe it is the the very small and lightweight rock chips that get stuck and cause damage. The bigger stones deflect out I guess. Anyway, like I said, so far so good, and as an aside I like the Forgeline wheels better than the OEM’s anyway. I’m still baffled why Porsche couldn’t come up an adequate design there. Spending $8k for PCCB’s and then having to suffer through watching them get chewed up is unacceptable. I really like the brakes and would do it again now that the problem seems to have been fixed by the Forgelines, although I’m not particularly happy that the solution required more cash out of my wallet when Porsche could have made this a non issue from the get-go.
#71
Does anyone know if this happens for GT3 and GT3RS?
#72
How can i measure or check if an after market wheel Will provide more clearance than OEM wheels?
#73
Basic Sponsor
Your car looks fantastic! Very glad you are happy. If you find yourself in town feel free to come say hello!
David Schardt
President
Forgeline Motorsports
3522 Kettering Blvd.
Dayton, Ohio 45439
http://www.forgeline.com
David Schardt
President
Dayton, Ohio 45439
Facebook Post
#74
Thanks for the feedback. I have read carefully your thread and would like to know what makes Forgeline able to solve the problem? Are they assymetric inside the rim in the area where PCCB calipers are?
I’ll let Forgeline answer the question about the wheel geometry if they are inclined to do so. Cheers
