Slotted Brake Rotors Coming To The 911?
I was at my local dealer today, Niello Porsche in Rocklin, CA, and was checking out a new Panamera Sport Turismo Turbo. First the new body style looks terrific and is a nice improvement over other Panamera's. To my surprise the car had iron slotted brake rotors and not drilled. I'm not that knowledgable on non 911 Porsche's but is this the first time Porsche has used slotted rotors on a street car? I'm not a fan of drilled rotors and I hope slotted iron rotors replace drilled rotors on future 911's.
DMoore
'18 Panamera Turbo Sport Turismo
'16 Cayman
'18 911 GTS (due in Port of San Diego in 7 more days)
Its about time. Other than looking nice drilled rotors just don't hold up on the track. My OEM drilled rotors and pads are in a box. They were swapped for Giros , which are slotted & RE10's.
If you really want rotors that brake the best, with the best most consistent brake feel, and last the longest no matter how hard they're used, take whatever you have and have them cryo'd. Whatever differences there are between solid, slotted and drilled, its nothing compared to cryo'd.
The steel rotor Panameras always used slotted rotors on the previous generation. So this is nothing new for the current Panamera.
Back in the day, it was believed that drilled brakes allowed gasses from heated pads to dissipate as well as to keep things cooler both allowing for better braking. This, as it turned out was not entirely true. However, many people equated drilled rotors to high performance cars. So, Porsche, and other high performance car manufactures continue to make cars with holes in the rotors because it "looks" right. If you look closely on late model Porsches you'll note that some of the drilled holes don't even go all the way through.
