iPhone Mount & Apple Car Play
I find it quite simple to just plug it in under the armrest and like the uncluttered look without a mount and running a wire.
I do find it fun how the text reader describes some of the emojis when it is reading a text. I got "smiling pile of poo" the other day. lol
No no, I mean attaching a ferrous plate on the back of the phone, over the receiving coil, will disrupt the coupling between the transmitting coil of the charger and the receiving coil in the phone. Four generations of Samsung Galaxy phones and now the iPhone have glass backs to allow wireless charging.
By the way, I have a Samsung Galaxy S8 and it appears to have a plastic back, though perhaps I'm mistaken.
Big Thanks to ATLBond! Re: Modified Rennline Cell Phone Mount
I had installed a Rennline cellphone mount which I coupled with an Ottie Qi wireless charging cradle and loved the convenience of quickly mounting and un-mounting the phone as well as easy wireless charging. The bracket supplied by Rennline places the pivot ball over the PCM which allows the phone to block the right side of the PCM display (this happens even if you use the magnetic mount they provide as part of the kit). With the help of ATLBond who in turn was provided a design by ValveFloat991, I sourced an alternative mounting bracket which places the pivot ball to the right and also higher up and now the phone cradle no longer blocks the right side controls nor the right edge of the PCM display. It's too bad that the Rennline mount does not come this way from the start.
Notice the blocked out right side controls as well as the right edge of the PCM) with the supplied Rennline bracket.
Here is my setup with the modified bracket installed. (PCM display and right side controls no longer blocked by phone/cradle). Far superior to the original Rennline design. Best of both worlds this way as no part of the PCM or the the right side controls are blocked any longer. I'm very pleased with the setup now!
99-911 (11-08-2023)
I plug mine in and toss it in the back seat. Install so clean you cant even see the phone.
The car play interface is enough. Stupid phone is only going to ruin my drive anyhow if I can see it.
Alternate Rennline phone bracket
The alternate Rennline bracket was produced from a CAD drawing created by Valvefloat991. A very generous member here on the forum happened to have had one fabricated from Valvefloat's design and sold it to me. If you have access to a machine shop, then can easily stamp out a metal plate using the CAD drawing. In the end, I only ended up using the aluminum pivot ball from the Rennline kit as I really wanted wireless charging and a secure cradle. The end product is very usable but not as clean as other solutions. What it lacks in elegance, it more than makes up for in usability. Placing the phone in the cradle or removing it is a one handed operation and as soon as it's in there, it's charging. All while allowing me to view the display for Waze, etc without blocking the screen on the PCM.
I originally used the Anker PowerWave Wireless Car Charger with the included vent mount, it worked ok but made it more difficult to use the touch screen. I purchased the Rennline Dash Phone Mount but didn't want to use the magnetic holder. The Anker PowerWave is an exact fit with the Rennline mounting ball. I think it could be enhanced a little bit more with the correct 90 degree USB - Micro cable.
Anker PowerWave fits Rennline dash mount
90 degree USB
The 90 degree micro cable provides more clearance to reach controls and the slack allows me to rotate phone to landscape mode
Clean solid mount, does block cupholder
90 degree USB
Trying to see if I can frankenstein a wireless charger to this Rennline mount (planning on high passenger side), maybe with valvefloat991 mod.
Previously, I had been using glue gun / superglue / screws between the following products to get an iPhone XS to get wireless charging on a Maserati Ghibli.
On the Maserati Ghibli:
1) http://amzn.com/B01FYBDCTU
The Maserati mount is not the awesome but it works (really need to clean this up)
- Bottom goes into the cupholder on console
- The ball is on the end of the gooseneck.
- Nut comes off and the cup with the magnetic head comes off
- Remove cup (this goes on the ball) from magnetic head (permanent damage)
- Discard the base (the one that sticks to the vehicle)
- Removed the "clip" from magnetic wireless charging head (permanent damage)
- Super-glue the cup from previous product into back of magnetic wireless charging head
- Add 4 small metal screws on the outer ring to hold everything together (glue was not enough to keep)
- The metal part that goes on your phone is a "ring" (hole in the middle) and not a plate so wireless charging will work
- The ring is ugly - it's a cheap silver metal ring
- Don't really like phone cases but this hides the ugly metal ring
- Just use painter tape to hold the ring against the case
- Case goes on the phone and seems to be ok
For those who want to use the Rennline mount (the one with the silver ball) AND have wireless charging, this somehow magically worked
http://amzn.com/B07DR9G4NL ($22)
Not sure how good the wireless charging portion works yet but the "mechanical" part fits the Rennline mount without any modifications
The problem though is I have it plugged into a USB in the passenger foot area (under the glove) and it is always ON (the charging circle is lit -- see photo) which may drain the battery. Anybody know how to make the 12V in the passenger foot well be on "switched" power? Only ON when the vehicle is running?
All sockets turn off after about 10-15 minutes. Leave the car with the charger in the socket and come back in 20 minutes and it should be off.
@ATLBond & @Valvefloat991 I'd highly appreciate if you can point me in the right direction to source this bracket or the closest alternative.
