PPF on headlights of 991.2 Need advice fast!
Old 03-10-2018, 11:34 AM
stick6
7th Gear
stick6's Avatar
Last fall, I had PPF on the full front of my '14 C4 at Unique Car Care without the headlights. Very happy with the result. Good folks.
Old 03-10-2018, 12:17 PM
mcipseric
mcipseric's Avatar
i don't do the headlights. removing the protection can crack the inside trim ring paint or coating. the dark ring around the outside of the light, behind the cover.
Old 03-10-2018, 01:40 PM
Ed911.2
Ed911.2's Avatar
My PPF guy definitely recommended against doing the headlights. Had the car nearly a year now and there are no marks on the lights but the PPF has saved a few chips to the front and hips already.
Old 03-10-2018, 03:27 PM
sampelligrino
sampelligrino's Avatar
Interesting, the guy I am going with for PPF (Moe @ GP) mentioned that he does 991 headlights most of the time with his PPF packages (of course it's up to the owner)
There are a handful of threads about headlight delamination on here. From what I've gathered I think it comes down to your installer specifically and your trust in him or her.. I fear more for rock chips and my LEDs getting blasted than potential delamination when you remove the PPF 5+ years later
Old 03-10-2018, 03:49 PM
digits
digits's Avatar
Once again, I discover how ignorant I am/was. When I had XPEL installed, I didn't know about making sure it got wrapped around all the edges. I got lucky, and that's how it was installed... Now, I learn that the headlights can be damaged when removing the PPF? That's just great. Fortunately, the installer covered the headlights with XPEL but did NOT wrap around the edges (or remove the headlight housing); there is a small gap where the PPF is slightly smaller than the surface of the headlight covers. Plus, it was obviously done with care; there's no evidence that someone scratched anything with a knife so I assume it was cut to size on a template rather than being trimmed after being applied. I hope the fact that it wasn't wrapped around the edges of the headlight is sufficient to prevent delamination if/when it is removed.
Old 03-10-2018, 04:13 PM
Hurricane
Hurricane's Avatar
The installer I am thinking about using is recommending wrapping the headlights, too. He does a lot of 911s and high-end cars. I haven't had it done yet, still on the fence.
Old 03-10-2018, 11:56 PM
MoeMistry
Premium Sponsor
MoeMistry's Avatar
It really comes down to installer skill and comfort level.
https://rennlist.com/forums/991/1030...-to-avoid.html
if it we’re my 911, I’d cover them in a heartbeat...but make sure you find an installer that has experience with install AND removal.
Old 03-11-2018, 07:57 AM
Rennolazine
Rennolazine's Avatar
How much are they charging for full front wrap? Trying to get some reference numbers. Thanks
Old 03-11-2018, 08:28 AM
72offsuit
72offsuit's Avatar
I had full PPF done by Esoteric, they removed the headlights and applied PPF. What will happen in 3-5 years, who knows but I am happy having them protected.
Old 03-11-2018, 10:26 AM
Gary JR
Gary JR's Avatar
Originally Posted by gellie
Why not have the headlights covered without removing the headlights? A good PPF installer can cover 90% of the headlight with minimal seams.
Exactly. Nothing difficult about this.
Old 03-11-2018, 10:58 AM
wareaglescott
wareaglescott's Avatar
I paid 2k in Atlanta. Front clip, door handles, side mirrors. Did not cover headlights.
Installer used Suntek film. I expect to get 5-6 years out of it.
Respected installer, does a lot of high end cars. Did a great job.
Old 03-11-2018, 12:30 PM
MoeMistry
Premium Sponsor
MoeMistry's Avatar
actually, it’s very difficult. Here’s an experiment you can do at home....get an egg out and a 2”x3” piece of paper, and try to cover the egg...let me know how it goes 😉
in all seriousness, headlights are extremely soft plastic and at 50-60mph, small rock chips might as well be little bullets. It’s the prudent decision to make ONLY if your installer is comfortable
Old 03-11-2018, 12:33 PM
MoeMistry
Premium Sponsor
MoeMistry's Avatar
you are actually somewhat correct...a capable installer can install a pre-cut headlight kit with no issues. Problem is, there will be an edge that comes about 3-5mm short of outer edge of headlight, and that edge is most often not symmetrical. But for sure, it would be functional and provide excellent protection
Old 03-11-2018, 12:37 PM
Nm2far
Nm2far's Avatar
Does anyone make the Lexan lens covers that attach with Dual-lock tabs similar to what is a very popular option with some touring motorcycles.? You know they are there, but are easily removed and protect like nothing else.
Old 03-12-2018, 09:21 AM
Gary JR
Gary JR's Avatar
Well that clears that up. LOL
I think many people will take the "edge that comes about 3-5mm short of outer edge of headlight" for the added protection.
Quick Reply: PPF on headlights of 991.2 Need advice fast!
