PCM settings won't save?
Cars about 2 weeks old. Some PCM settings won't save. On the sports chrono the Individual settings won't save. On the settings menu i deselect "mirror lowering on reverse" and it goes back to checked on next start up. I increase the volume for park assist from medium to loud only to have it go back to medium on next start up. Anybody else have this problem?
Yup. Every time I adjust something, the next thing I do is hit "Memory" "1", "Memory" "2", "Memory" "Key". I'm the only one that drives the car, so no need for different saved settings.
It's quite annoying when equalizer settings have to be adjusted each time unless you store the memory.. Then you find out each media player has it's own equalizer that has been set.
I'm just glad the A/C has stopped kicking on every time I start the car.
BerlinDaniel (08-03-2022)
Nino, How'd you get the HVAC to stop? I've tried every solution posted in these forums and it'll still go to 72 every time I start (I have a 2018).
Also gets annoying when the A/C is kicked on while I'm using the heater.
I stored the memory to the key as mentioned above.. First I saved it to 80 for the winter but decided it was still annoying so I turned off the HVAC unit completely and then set the memory to the key.. Now my climate control unit stays off unless I turn it on.
If you want it off, turn off your climate control and then save it to the key. This way when you start the car the climate control will stay off.
Turn on your climate control to your desired temperature and fan speed setting. Then save the memory to the key. This way when you start the car the climate control will be on exactly how you programmed it to the key.
I must be doing something wrong. How to you set it to off?
