Warm Up & Cool Down - 991.2
This tread brings me to a somewhat unrelated question: when the auto start/stop is activated, and when engine stops for instance at a traffic light, does it also stop the circulation of oil? And if yes, wouldn't this be harmful especially for turbo charged engines?
Great question..... don't know the answer but the fear of a shorter life of the turbos because of a sudden lack of lubrication and cooling is the reason why I always turn off auto start/stop.
Am I missing something, or have the parameters of lugging changing since the days of the Fuhrmann engine?
It’s not about Porsche torque claims, it’s about putting stress on transmission and engine.
I dont think you’re going to destroy your car or engine.
But the fact that the car “allows” you to do certain things doesn’t mean it’s wise or that it cannot be harmful or it’s better to be avoided.
Dont take my word for it. I had not seen this article or video before but google is your friend.
https://www.roadandtrack.com/car-cul...ad-for-engine/
The same for this obsession with pre-ignition. Modern engines that are not worn out aren't full of oily blow-by and glowing particles of carbon. They are simply not subject to pre-ignition. Turbocharged engines are, of course, always susceptible to detonation, which is something completely different and definitely potentially harmful. That's why modern engines have knock sensors that detect the earliest signs of detention and retard spark timing, reduce boost, and/or richen the mixture in order to stop it quickly.
In this litany of nonsense, nobody discussed the only genuine potential problem with the combination of high load and low rpm. That's damage to the main and rod bearings that could occur when the combustion loads on these components exceed the hydrodynamic pressure of the oil film, which is weakest at low rpm. This would cause the bearing shells to physically contact the crank journals and that would cause undesirable wear, or worse. However, I would expect that Porsche engineers thought about this when designing their engines and made sure this wasn't a problem.
In any case, there's no doubt that for maximum acceleration, one needs high rpm and low gear. But for moderate acceleration, full throttle in an upper gear is often sufficient. I have no doubt that a 991.2 engine can't possible be adversely affected t by full throttle at 2000 rpm. I'm pretty confident about 1500 rpm as well. 1000 rpm might be a different matter--but then the engine can't make much boost at that rotational speed so perhaps that's also OK.
The following 2 users liked this post by Valvefloat991:
DR911s (05-10-2023),
PorscheRob23 (01-25-2024)
2nd Gear
Thanks for all the tips. Recently moved from a 2017 Cayman 718 Base to a same year 911 Carrera S. Literally the day before my planned trade-in pick up I took the 718 for a spirited drive (although it was still in suburbia, so didn't see much harder than I've pushed any other car over the years, including Audi, BMW, etc.), and on my return trip home it started blowing gray/white smoke like I had lit a smoke grenade while taking enemy fire. After making it home, having cleared out some two lanes of traffic behind me along the way, I noted oil dripping from the tailpipes. Thankfully, as the 718 was still under warranty, the dealer took it in trade anyway without any hassles. Turns out the turbo had started sucking oil into the engine. However, this gave me a bit of PTSD, and I've since been nervous to drive the 911 aggressively at all (it still has a few months of warranty left, and I plan to buy the extended Porsche warranty unless someone here suggests something else that makes more sense). It's only been a couple of weeks, but trying to make sure that nothing I did in my last 718 drive contributed to or caused this, so I don't end up with a costly repair on the 911.
For turbo charged engines, lugging is bad. Lugging the engine will depend on the gear but as key takeaway, don’t drive near or below 1000rpm. In 2nd and 3rd, don’t go below 1300 rpm, in higher gears stay north of 1500-1800 rpm. Personally since I have a manual, I prefer to stay north of 2500 rpm, engine noise is not too loud for cruising and still have good up and go.
