Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#3556
One of the head unit manufacturers "Mekede" offers much more professional support and they have what's likely to be the latest version of Carlink on their downloads page here
Support / Software Download Address (mekede.com)
I would use this as a very last resort though as we should be able to get your unit working and if you upgrade to the later Carlink and find it's not compatible you might not be able to get the old one back without doing a full factory reset
Have you gone into the Carlink app to see if it is telling you anything?
Latest Uploads - APKMirror
The latest version of Zlink is 5.4.41 and is available from this link - older versions going back several iterations are also available. If anyone is running a version of Zlink before 5.x.x I recommend they update as the v5 series is much more reliable.
ZLINK for Android - Download the APK from Uptodown
Personally, I'd be a bit wary of that apk on the Mekede site as it seems to be a customised version and may have been modified for their own brand HUs.
#3557
Boot animnation updated
I successfully updated my boot animation file to get rid of the Android logo on startup, My HU now boots up to the Carrera S silhouette followed by a nice Porsche logo with a subtle glow animation.
Its easy enough to do and is very briefly mentioned at the back of the guide. I will do a fuller write up as you need to run a backup script to extract the updater file. I think you can also update the boot logo at the same time.
Here are a few pics of my startup sequence of: logo > animation > Agama launcher
Apologies for the huge reflection in the pics and its a shame I can't post a video here, but you get the idea!
andy2111 (08-03-2024)
#3558
@jadski have you looked in the "app store" app for updates?
There is a newer version of CarLink available if you've not already tried it?
And as well as my suggestion above about the auto-start in the factory settings, there is also this setting in CarLink itself - have you checked to see if the automatic connection is enabled?
ZedZed (08-03-2024)
#3559
As I had all the updates shown above available, I decided to update everything, but was mindful of @ratt359 's experience when he did this as the "bright lights" bug came back and he had to reapply the fix and pull the HU fuse to get it to work.
All the apps updated except "Protocol update" which downloaded but did not want to install.
There was no obvious issue with bright lights, but I decided to pull the fuse to force a full restart just in case the lights returned once the canbus had been fully restarted - but everything seems fine
I'm sure I'll regret sayng this... but I think my Chstek is now fully configured, customised the way I want and has everything working as expected - I'm sure it'll explode in a ball of fire tomorrow! Or Porsche will announce the release of PCCM for the 991!
#3561
I'd do it if I listened to 'normal' radio, but I listen to digital stations via a USB DAB tuner and use the DABZ app which has a nice UI
I love the idea of the proxy, wish someone made that for all buttons!
#3562
CarLink was already selected. I tried toggling the easy connection option which didn’t work.
I then went to the App Store and opened Carlink
I hit the open button and fixed! Thanks so much for the suggestion. I would have spent hours troubleshooting.
#3563
Just do a video on youtube and post the link here
StanfordBear (08-03-2024)
#3564
Yeah, I know, but the pics are fine I think.
If anyone wants to see a preview of all the boot animation options, there are a load of .MOV files in the boot animation folder in the same place you find the guide:
BootAnimation - OneDrive (live.com)
Once you decide the animation you like, download the zip file of the same name, rename it to bootanimation.zip and update it (I will add the full process to the guide soon)
#3565
I am trying to install my chstek today in the Macan. This connection is not mentioned in the guide.
Could someone please tell me what this fakes connector is for?
Also, do I need to connect these aux in to the corresponding connectors from the wiring harness? I did not see that mention in the installation guide.
#3567
The only issue I now see with CarPlay is that if you accidentally use any of the hard key buttons, it kicks you out of CarPlay and back to Android mode. Android mode is limited because it is still thinks its connected to CarPlay. When I try to use Carlink to reconnect, it just stays in the verification process and won’t come back on unless I go into the iPhones CarPlay> forget device and then reinstall it.
#3568
I have Bose and everything is working so I guess I don’t need those aux connections.
Thanks for the quick reply.
Also, my factory camera is working right out of the box. I connected the CAM VIN yellow connector from the wiring harness to the yellow male connector from the HU
#3569
jadski (08-03-2024)
