Has anyone done a CarPlay retrofit / Headunit replacement for 991.1
#3496
My car is manual which is what Isudar says is part of the problem. Below is a picture of the instructions they sent as to which wires to connect, and a second pic showing I did exactly what they instructed. As mentioned earlier once I did this the rear camera then started working, unfortunately it appears to have constant power and the radio thinks the rear camera needs to be shown at all times:
#3497
Hi everyone,
I’m excited to announce the publication of the CHSTEK 7862 installation and configuration guide.
This latest work builds on the foundations of our first guide, but now focusses specifically on the CHSTEK 7862 because it is (currently) the unit that everyone is buying and asking questions about.
There’s lots of new content to help first time installers and likely some info that existing CHSTEK users will find interesting, especially on settings and system menus. Highlights include:
If you see anything wrong or missing then please provide as much info as possible, including screenshots if applicable, to help minimise the workload in keeping the guide up to date.
Enjoy!
Andy2111 ZedZed and Ratt359
The CHSTEK 7862 guide can be found in the Guides folder here and in my signature below
- Buying guidance
- Tools and adapters required for the installation
- Configuring Bose and SPP audio
- Initial configuration and settings
- Backup cameras for PDK and manual
- Quick reference guide to all the system menus
- And lots more..
Enjoy!
2.You want the car in the ACC sleep mode. please check below:
#3498
and a couple more pics showing the radio installed and the backup camera functioning. Just a note in these pics I still have the protective film on the radio from shipping if it looks a little off, so you are aware.
The following 2 users liked this post by dav9515:
Porsche_nuts (08-01-2024),
StanfordBear (08-01-2024)
#3500
ZedZed (08-01-2024)
#3501
edit: Opps, didn't see the same suggestion posted. That's more accurate.
ZedZed (08-01-2024)
#3502
CarPlay help...
Can you tell me what is a available to convert my 2013 991.1 with Burmeister amplifier to accept Carplay. Is this done with a new PCM 4 head Unit or a conversion box with Ribbon Cables, etc
#3504
@dav9515 Thanks for the pics. Another question: Were you able to use the original factory GPS antenna & factory 4g/phone antenna? Did you need to separately purchase FAKRA C-SMA & FAKRA Z-SMA adapter cables?
On the other suggestion on using the Blue/white wire under the seat, the whole point of me getting Isudar instead of the Chstek was to have OEM camera integration without the need for additional wiring. If it doesn't work they way they say it should there's a good chance I just return it and get the Chstek for the larger screen while still having *****.
also wanted to clarify for everyone how Isudar runs their wiring since it seems it could work for any radio, they have their quadlock connector that goes to the OEM quadlock. From there it goes into their power connection that plugs into the back of the radio. Off of that they have taken the wire that brings in the back up camera signal and put an RCA cable on in their wiring harness provided. This RCA then plugs into the RCA in for the backup camera that plugs separately into the back of their radio. Picture attached
#3505
I don't have either of those options in my car so can't answer that unfortunately.
So this RCA male is exactly the same as what the CHSTEK unit comes with. So I guess our guess was correct that connecting this male RCA to any one of the RCA input will display the camera
#3507
Yeah PDK and Manual matters. If you read further back in this thread you'll notice the CHSTEK folks was trying to figure this out as well back then 😅
#3508
If you have a manual transmission, I don't think any HU has a way to avoid tapping into the reverse light to signal the HU when you are in reverse. At least the above gives users an option to still use the factory camera. They just need to connect a signal wire, so the HU knows when you are in reverse.
#3509
That said I hope we can help resolve the technical issues to give people a choice depending on their preferences.
We're gonna need a volunteer to write an install guide for the Isudar!
#3510
next time I'm in there and trouble shooting I'll try and chase the RCA wire to the quad box and see where it connects. Right now it's about 120 degrees in my garage and I'm done sweating for the day. stupid humidity!
