Has anyone done a CarPlay retrofit for 991.1
#392
If it's not too much trouble, could someone take a pic of how they've mounted the USB in the centre console? If all goes well I'm hoping to finish this weekend .
I found an interesting route for the camera cable. Will take pics!
#393
Red Cross indicates where I cut/scored the rubber mat to fish the USB in the console.
USB Cable routed thru Center Console.
#394
Thanks, Sid! That makes sense. Your help with this is truly amazing. We all appreciate it!!
#395
One more dumb question from me! Did you guys connect the ground wire at the PCM harness end, and if so, to what? It looked to me like that ground isn't needed unless using the 360 camera wires.
edit - yes, I'm an idiot. I found the info. looking through the thread
#396
Ground Wire
Ground Wire to PCM on Main Harness.
Black Labeled 18-20 gauge ground wire soldered on main kit harness.
Tesa Tape
point to the car’s chassis by taking the thin (18-20 gauge) black wire marked ground and bond it to the main harness loom provided it the kit. This requires removing the Tesa Tape (Black Cloth Tape) and bonding/soldering it to the ground wire in the harness. This process is time consuming and requires patience and care to avoid cutting in to the harness wires. I also purchased Tesa Tape from Amazon. The attached schematic illustrates the ground for the PCM (refer to red arrow).
#397
Working! Sort of. Rearview camera is 100% functional and works as expected. Android Auto is very, very buggy. I messed around for about 20-30 minutes late last night and only managed to get it working once.
I wanted to verify my work this morning, so I plugged in my wife's iPhone and sure enough it worked perfectly and straight away.
I'm hoping the latest firmware will do the trick for me - just in the process of scrounging around for an old smaller format USB stick to give that a try.
#398
#399
I managed to have that issue on one or two of the attempts, but most of the time it just failed to recognize the phone. I'm wondering if the supplied USB extension is just too much extra cable. Nick alludes to this being a potential issue in the firmware notes, so now I'm not so sure v269 will help.
#400
Hi,
Please email us so we can look into, we've tested AA on several phones with good results. Would be good to get more info on what's going on.
Cheers
Nick
Cheers
Nick
#401
Thanks guys, this is interesting information on AA. Hope this gets fixed for you all.
#402
So, strangely enough - Android Auto is working normally in my testing tonight. I have no idea what I was doing wrong last night, but this is a positive sign.
Also, I found a way less frustrating place to route the rearview camera wire. I removed the plastic trip up at the top of the engine bay, directly below the rear glass. You still have to chop off the yellow composite connector to fit it through there. All I did was to remove the blue pressure fitting for that one hole (there are still 4 remaining).
#403
#404
Those 5 holes are not sealed from the factory. I'll take a photo of the back of the plastic trim, but there are literally just 5 pressure-clips like these ones, but blue in colour.
I'm surprised Porsche wouldn't use something with a grommet there to make it water-tight. That said, there is a rain channel built into the top of the black trim piece, so I imagine that must route all water away from this area and down to the left and right edges of this trim.
#405
