Has anyone done a CarPlay retrofit for 991.1
#181
So I received my Unichip Carplay retrofit and it was relatively easy to install. But it seems to have a ton of bugs. Has anyone else here installed this particular unit? It randomly turns on and off and does funky things like turn on after the car has turned off.
Anyways, I am waiting on the manufacture to see if they might have updates. It's possible I just have a defective unit.
#182
yes, wher did you get your unit? the one from China or the one from th UK? i’d love to get an ApplePlay but if it has problems guess i’ll have to wait for one that works.
#183
Live and learn
I'll probably reach out to Nick to see if he can sell me a support package for the firmware updates and standoffs.
#184
CarPlay
I’m also considering the CarPlay device. So far I’m hearing the Unichip device from China has some issues. On the other hand, I’m hearing positive feedback from Nmautomotive.uk. I also reached out to Nick from NMautomotive inquiring about his kit and whether the satellite radio PCB has to be removed to install the interface PCB. Nick stated his device will work without having to remove the satellite PCB. Here is a list of items that come with his kit. I was also informed a two part firmware installation is required and it’s the buyer’s responsibility to provide a USB flash drive at size: 1GB - 16GB. You can elect to use one flash drive to download the firmware (info is provided in 45 page instructions), or use two flash drives to download two separate pieces of firmware. The flash drives need to be formatted in FAT32 before you download the firmware. From what I’ve read the installation will require at least four hours to complete and the conversion is rated at a difficult level.
The CarPlay kit consists of the following:
1) Sub-board to be installed in the PCM.
2) Separate CarPlay unit, normally installed 'hidden' behind the PCM.
3) Wiring harness.
4) A high quality/small Parrot microphone, stand-off studs to allow Sirius XM to be maintained, a USB extension to allow the USB to be positioned as required or as an option a USB adapter allowing the glovebox USB to be used exclusively for CarPlay, and remote installation support.
3) Wiring harness.
#186
Shout out to Nick!
I PM'd him and he replied with ALL the support docs eventhough I didn't buy my kit from him! I even offered to pay and he just sent me all the information. Once I apply the updates I will update the forum. Thank you Nick and moving forward you will get my all my business and referrals from my local Porsche Car Group.
#187
Shout out to Nick!
Am assuming you did a self install. How would you rate the difficulty of doing the conversion?
#188
A ton of effort has gone into all his documentation and kit assembly. I think I could do an install in maybe 3-4 hours if I really took my time and 2-3 hours if I rushed now that I have done one.
#189
UPDATE: using the latest version of iOS on my IphoneXS MAX and I am happy to report everything works perfectly.
Thanks again Nick for all the help! Definitely a huge asset and great vendor to our community.
If any SF Bay Area folks decide to purchase his kit, I am happy to demo the kit and help with local trouble shooting.
#190
Nick has answered many of my questions and sent informed about the installation. I've talked to one installer he wouldn't open the pcm and install the board. I'm still searching for a shop to do the install.
Cman21
Cman21
#191
Hey Joe, good to hear everything is working out. How are you liking it? Any quirks we should know about.
Going back to installation, would you say that the various YouTube vids out there are accurate regarding the taking apart of the PCM and the removal and replacement of the ribbons is more or less accurate? Of course, the vids make it seem relatively easy, but would you say that Nick's instructions are more accurate and maybe easier?
Thanks for the input. I am not an iphone guy and am basically waiting for Nick to perfect AndroidAuto and may even wait a little longer for him to perfect wifi.
#193
So far so good, but it's only day 2. But now i just leave my phone in the glove box, when before I had it mounted in view.
#195
