911 Carrera T Locked & Loaded!
#76
I think you've chosen the best colour for the T and the best gearbox both incidentally free..PCCBs would be the first extra cost option i would pick and a close second would be RAS..I drove both RAS and non RAS 991S's at Silverstone last February as i was undecided on speccing it for my April build 991.2 GTS..I thought RAS was transformative at all speeds and while the non RAS understeered the RAS car turned in like a GT4 and was much more agile and neutral at all speeds.
RAS is unavailable on the basic 991 and by adding it to the T will give it the USP it deserves and give it a handling advantage over the basic 991.It also reduces its turning circle at low speeds making parking easier.
I fully realise its very easy to spend other peoples money however on the T the combination of manual,PCCBs and RAS will make it a cracking car..I also think its a wise decision not to spec the glass roof to keep the lightweight T ethos intact..
Thanks, Taffy. More food for thought!
#78
I got 2% off MSRP.
Just got my build date for April, so hoping car arrives May.
My build goes a bit against the spirit of the T, but because it will be my daily and not a track car I took the plunge when optioning out the car.
- PDK
- Glass black sunroof
- Black front LEDs
- Black tail lights
- Color: standard White
- Interior in white/silver
- White instrument cluster + analogue
- RAS
- Entry+Drive keyless
Can't wait
#79
I can't wait until I win mine in the PCA raffle. I have a 50/50 chance. I'm either going to win or I am not. Right? Plus! I have a REALLY good feeling about his one. :-)
#80
I did just this. Main car for the test was a C2 manual with RAS and steels - closest I could get to my T spec - and then a C2S manual with PCCB.
#81
PCCBs on the street? Hell I cant make an argument for them on the track.
I just think the T is more performance oriented in my mind and in my head it screams for PCCBs. Yes the T I would spec would be a weekend toy. Were I to get a DD Id go with the base PDK, 14 ways and a few other options.
Other than the fact that PCCB's don't have a ton of stop when cold, they are better for a majority street driven car no doubt. Compared to a 380mm brake you can feel the difference in unsprung weight, granted we're comparing to a 330mm setup in this case, but how does one not want 410mm lightweight rotors on a somewhat lightweight themed car?. I have a base car and I will say the 330mm brakes seem a little underbraked compared to the 380's and PCCB 410's. I think the pedal firmness on the PCCB setup is a step up. And no brake dust. For a car seeing heavy track duties the PCCB option would in fact not be desirable based on the costs and wear and delicacy. Heavily tracked cars always run standard brakes.
#83
PCCB's are never practical, but man, I just love them... we're trying to spec out a Macan GTS for the wifey, and I keep saying we need PCCBs on it...especially since I'll be doing a lot of driving myself
#84
Blueflame,
It is a fairly easy job for your dealer's parts team to order up just the yellow door pulls and then have them swapped over before you take delivery. That's what I did in my Cayman GT4 as I wanted red door pulls to match the red belts I spec'ed but the factory said no. The dealer did the swap over and it made a huge difference to the interior. Here are a before and after shot.
