My tail light fell out!
So, last night I was driving and I pull up to a stop light and a guy in a work van next to me signals, roll the window down. He then proceeds to tell me "you light is off." I pulled over thinking it was just a bad bulb and to my surprise I find the entire passenger side tail light hanging by the wire off the back of the car! I then just unplugged the light and took it home with me.
Anyway it looks like the plastic on the light cracked somehow and now I need a new light.
Couple of questions:
1.) anyone else experience something like this?
2.) I just purchased a tail light on ebay but the part number is different from the number on my original light. - will there be an issue using this tail light?
The part number from my light is 991.631.146.12 and the one I bought online is 991.631.145.13
3.) should I install the new light or bring it to a specialist - I know this is subjective but what would you do?
https://rennlist.com/forums/991/9601...apped-off.html
After some arguments it was replaced under cpo warranty.
updated version look like this
Blk991cab
the 2 part numbers you quote are for different sides ... one is right, the other left
http://www.gaudinporscheparts.com/?y...&search_in=all
http://www.gaudinporscheparts.com/?p...991.631.145.13
Who is working on your car man?
Misaligned exhaust - missing parts from headlights, half asses lettering. No offense but you can do better with this car and find someone else to work on it cause any reputable place would have coached on the lettering, aligned the exhaust and put all the parts back on the car after taking them off to remove your bumper.
Why was the bumper removed? I'd be concerned about what else was hacked up that you can't see from internet pics.
I believe Chauncey is gone and my favorite and only guy I used to trust Justin is also gone too. Replaced by a jeep/Honda salesmen....
Received 5,388 Likes
Seems to me like someone not only forgot the covers but also forgot the 2 bolts that hold that light in...If you've taken it in for campaigns, there are some that require removal of the taillights.
huntflyer (03-29-2024)
Make sure you inspect to make sure they remove any rags from the engine bay and I'd also check the lug nuts on the wheels to make sure they are all there and tight... Wouldn't trust them to put air in my tires at this point.
People wonder why I DIY everything. Partly it's because I can't justify spending $400 on an oil change that takes me 20 minutes. But mainly it's because too many mechanics simply don't give a **** and you end up in situations like this.
A dealership does not charge $400 for an oil change. My oil change two weeks ago was $182.55 (I provide the Mobil 5W50).
You can NOT change your oil in 20 minutes. No way, no how- set up all your tools, get the oil warmed up to +180, drain, fill, check proper fill level, put away all tools, clean up, take old oil to recycling center....in 20 minutes.
But, we get your frustration.
Well, fine. 20 mins is an exaggeration. But 30 mins is not. Did it a few weeks ago. It's a drain plug and an oil filter housing. It's amazingly simple. Not at all like a 993, which is a massive PITA.
Even my taillight fell off! WTH!
Was driving on PCH, curvy road. All of a sudden check right read light warning comes on. I stop at the next gas station and the entire light is missing with several scratches on the rear bumper. Will Porsche take accountability and fix this?
The light bounced around and left several scratches on my rear bumper.
