DSC Module USB Question
For those who have connected their PC to the DSC module to modify, what type of connector did you use? Went out to the car today to modify the DSC, I tried 2 different standard USB cables but they didnt fit the opening properly. Is there a "special" type of USB to connect to the DSC? I should have snapped a pic.
I was a bit impatient since its 100 degrees in the hatch, didnt want to spend any more time than necessary. I can try it again if you all tell me a standard USB will work. Thanks.
