My 991 TTS Champion Turbo Upgrade Thread -- RedGutz Gets 68mm VTG Upgraded Turbos
My car is currently at Champion Motorsports getting her upgraded 68mm VTG turbos. These are stock housing turbos and my understanding is they are similar if not identical to the ones Sam's customers are getting.
Once the installation is complete, the car will receive an updated GIAC tune with pump and race gas files.
Unfortunately, Champion's dyno was broken when my car came in so I do not have a before dyno. Grrrrr. I will receive after dynos and will post them when I receive them. I do not expect to be able to take this car to the dragstrip until next spring as by the time I get it back it will be too cold to get drag times if the strips in New Jersey are even open then.
In terms of power this will NOT be a record breaking or event car. No meth. No PDK upgrade. No nitrous. I am a rally driver first so the car must be reliable so I my instructions to Champion are not to tune the car to the brink or anywhere close to the PDK limit. I just wanted more power especially on the top end where the stock turbos run out of power.
Car should be good for 660-670 wheel HP on race gas. Or so I hope. We will see when she gets on the dyno and is tuned.
Here are the pictures that Champion has taken of the project so far. Note that we had to drop the engine to replace both turbo oil lines because these metallic lines has corroded (those damn NY winters).
Agentorange (05-03-2020)
Originally Posted by SamboTT@ByDesign
Excited for you Scott. It will be a completely new car!
Originally Posted by Nanook
Welcome to the "big boost" club
I don't mean to hijack the thread but I have to ask.
I'm contemplating between a new TT and TTS. To my knowledge, the only difference (engine related) between a TT and TTS is the bigger turbo on the TTS, correct? If so, I'd rather upgrade the turbos like this. Thoughts?
How much did this set you back, if you don't mind me asking?
Kline headers+these turbos+a nice exhaust would unleash the the beast in a 991.2 TT/TTS, right?!
There is no tuning available yet for a 991.2 TT/TTS as I understand they are still working on breaking into the ECU. My own belief as to the most effective power mods on the 991.1 TT/TTS are:
Tune
Intercoolers
High flow cats/catless exhaust
Turbos
Meth
Basic Sponsor
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
Very interested as there's no awd dyno around here so I never got to run my stg IV but we should be very close..
Also are you running 19" rear wheels ? Sidewall looks tall
Good luck
Good luck
