Techart Nose Lift Kit Compatibility
I'm starting to explore options for lowering my 991.1 TTS and pairing it with Techart's Nose Lift system. Techart's 30mm drop feels a bit too much for what I'm wanting to go for, and going down the route of pairing the lift kit with Bilstein B16 coilovers might be overkill (according to this, they're compatible —*https://rennlist.com/forums/997-turb...ide-input.html).
KW makes a set of height-adjustable springs which allows for a 20–25mm drop, which is what I'm going for. Does anyone know if these springs will work with the Techart lift kit?
