Tracking the Turbo
#121
I run Pagid's on the race car. I don't recall for sure but think they are yellows. My car (986 S) stops unbelievably well. My other brake mods include ss lines, high temp,fluid, GT3 master cylinder, and GT2 brake cooling ducts. All that and significant pro coaching solved all my brake overheating issues. At Sebring. In the heat of the summer.
#122
It was a huge improvement so I think I will change before next track session.
#123
Guys, looking for recommendations on track pads for .2 turbo? Not unhappy with Porsche pads (2 sets so far), wondering about experience with other pads on the track.
Currently running:
- SC2's or Trofeo R (depending on what's in stock)
- SRF fluid
- Forgeline wheels
- Camber -1.9F -2.5R
Approx 20-30 track days per year. Not a DD, but does see a fair amount of street use.
Currently running:
- SRF fluid
- Forgeline wheels
Tell us about your experience on Cup2's vs Trofeo's
#124
Why are you not happy with the pads? What's the source of the unhappiness?
I love the stock TTS pads for their initial bite on track - I can brake later - but as soon as they cool off they start to flake and crumble and generally sound really terrible on the street, and they don't last very long for track use.
I tried Pagid RSC1 and generally liked them from the perspective of holding up to the track, but they didn't have the same bite. Never much fade. Finally, I tried the OEM GT3/GT3RS/GT4 pads for PCCB and they are very similar to the Pagid, but much cheaper. I wish there was a pad with the bite of the stock TTS, but didn't chunk up. For now, I'm going to use the TTS pads for autocross and stay with GT3RS pads for track.
#125
My $0.02 in opinion on the tires:
Stock P Zero's - Good for daily driving and when it's pouring rain at the track. On dry track limits are low but provide lots of notice before they give up.
Cup 2's - On track more stick than stock P Zero's, fairly even wear pattern, plenty of tire squeal when approaching limit, feels like they heat cycle out before wearing out
Trofeo R - Most stick of the three, outsides wear very quickly if no camber adjustment, with camber adjustment better wear pattern but not as good as the Cup2's, least feedback of the three when they approach limit.
I run the stock P Zero's on the factory wheels and usually opt for the Trofeo's for track day wheels.
Hope that helps.
Hope that helps.
#126
Just looking for other peoples experiences with different pads to try.
#127
Gotcha, now I have the context. I also use React fluid, too, which I just have a ton of confidence in.
#128
Hope that helps.
Hope that helps.
Now that I put on more camber tire wear will improve, so I think Trofeos will be next.
#129
http://www.paragon-products.com/Pagi...4927-pagid.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
#131
Are you tracking with the nanny on?
I was frying the PCCBs on my 991.1T because the system was so active.
The brakes were way less stressed with the nanny off and lasted a lot longer.
It's a shame the Turbo doesn't have separate controls for ESC & Traction control like the GT3.
Cheers
Cheers
#133
Randy I think the issue is more related to the PTV activating which I don't believe triggers the ESC warning. I rarely saw ESC interventions but the brakes were cooking (on some tracks).
I now have a GT3RS for track and it doesn't exhibit the same issue, Im guessing because of a combination of less weight and less aggressive PTV system.
But I agree, smooth is best
#134
PTV is mostly active in the rear brakes. A lot of track guys say their rear brakes wear faster than the fronts, but I have not experienced that. My fronts wear faster than the rears. I think the track does play in big role. VIR is technical, but also very fast, so I think it probably averages out.
#135
Cheers
Cheers
