Tracking the Turbo
#76
Results
Can't wait, things getting installed now. Keeping street ride but sport mode will be much better. Black/black with OEM powder coated extra wheels and a couple sets of Trofeos, Pagids to go with the ceramics, widened front end, lots camber all around. The DSC for suspension control and improvement. A little sound to bring some life to things too. More when I get to sort it out.
Got to the track and had a chance to run this set-up more. Goal was to maintain street ride but improve track ride in Sport without harshness. Firmer cornering, less brake dive and acceleration squat, better transient response, flexibility to tune and change configuration. Camber at 2.8 & 2.4. Widened front end, and improved stick all around with the R's over stock of course.
Comments:
Rennline mesh grille guards – center and sides, front bumper has to come off, so a bit of a pain. The mesh is alloy and stronger than some of the plastics so was worth the effort to me.
AWE mirror wind deflectors – worked as advertised, easy install, front leading corner of both has no mount so they are loose up there. Easy to fix and modify sometime.
Pagid RSC1 pads - more even modulation and not the high initial bite as OEM with ceramics.
Tarett front camber plates, front lower control arms, axel spacer kit, shims, lower control arm spacers, rear long & medium upper control arms, boot ends – This set-up is great, it gave me the camber adjustability I wanted and more. Now soft tires can be run with even wear, temperatures, and proper full contact patch advantage. Added much better road feel and responsiveness. Some rubber bushings were replaced with mono/spherical so some less deflection, but enough rubber left to keep DD ride.
DSC V2 controller - Easy install, product does what is advertised well. Brake dive and acceleration squat were cut in about half I’d say. Ride on initial travel of shocks is smooth but does firm up well upon harder cornering and Gs. Better stability. Street is good, but Sport is definitely improved.
Sharkworks catback exhaust - brought some life to things, at start-up fast idle they are some louder. Once idle settles noise is a little more than OEM. Things change upon throttle or above 2000 rpm. They sound off at a nice medium level and have some deceleration burble. Great happy medium to me, quiet at freeway low revs, but anytime you get on it sound arrives. Not like a GT3 rev to 9k or a catless header system by any means, but a good street compromise.
OEM wheels, powder coated, Trofeo Rs – Nice stick as expected over OEM PZero, they will wear quick too, no surprise.
Feel and handling – Overall car has more road feel and control, little more noise on rough surfaces. Going to try some track tuning of DSC and more tire pressure changes, default DSC is very good though. The OEM understeer is gone and the car can be driven with the rear as needed. Really happy with changes to the car and would recommend something similar for those with same goals. If you’ve driven fully set-up track cars this is not going to compare with the taught-ness, rigidity, flatness and turn-in of a car with firm springs/coilovers, steel bushings, big sways, or raw exhaust sounds. But I can’t think of a better dual purpose ride though!
Hats off to a couple of shops in particular, Cantrell Motorsports, and Tarett Engineering. Great folks to work with and the package hit the bulls eye for my wants.
#77
I used up my Pagid RSC1 brake pads, and this time I tried the Porsche OEM pads for the GT3RS/GT3/GT4 with ceramics. I liked them much better than Pagid or TTS stock pads. Bite is better, feel is consistent and strong, and I just had a more confident response from them. TTS pads stop great, but they scream and pop and grind like crazy back in the paddock after a session - they are not designed to handle the heat of a track session.
Also, GT3RS pads (for ceramic) are cheaper than anything else if you get them from Suncoast. I put a couple of days on them so far at VIR, and heading up to WGI next weekend and will report back again. So far, my fav of the three.
#79
I have a standard turbo s rims being 9*20 et51 front and 11.5*20 et56.
Having read this thread I am planning to go 265 + 325 combo michelin cup2.
Do you go the route 265/35/20 + 325/30/20 or 265/30/20 + 325/25/20?
I am at stock suspension and don't want any rubbing etc. The reason I want to go wider is:
1) I want to have better grip given that the car will have increased dynamics
2) I may use it several times at the track events.
Thanks in advance for advice.
#80
In the process of selling my 997.2 Turbo S which is my track car as I have a deposit in for a 991.2 GT3 but won't come for probably another year (down the line for second round allocation) so I'm going to try a track day this weekend with my 991.1 TTS.
Tire pressure question for you guys on the .1 PZeros N0 spec - they seem to rise dramatically even on simple spirited drives on the street. Where do you start the pressure on a track day? Forecast is low 70's early climbing to 80's afternoon. I hear mid-30's is the upper limit so will have to start really low and do a couple warm up laps I suppose.
#82
Originally Posted by Randyc151
I am willing to start out at 26 all around, and then bleed to 32 front/ 34 hot. Take it easy on the first couple of out laps, and then crush everyone!
I have a feeling I will need tires after this track day despite only having 4,000 miles on them (in two years lol). Do TrofeoR's come in stock TTS centerlock sizes?
#83
Thanks Randy. I was afraid of that (needing to start low). The track I'm running is very tricky to get pressure correct. It has a banked CCW Roval for nearly a mile and a TTS can hit speeds well in excess of 150mph so I need to keep the passenger side tires more inflated (for safety reasons) even though they wear/warm faster than the driver's side. Sounds like I will need to start pretty low and warm up for a couple laps, do one hot lap and then come in and bleed and repeat.
Agree with Randy on air, you do need to start that low then bleed off as day heats. I do run a little less at front, 30-31 hot. Will depend on your cars alignment and configuration, assuming OEM. I run Torfeo Rs on OEM wheels and they do come in sizes you need.
#84
Thx. I'll prob burn through these tires and need to look for replacements. I have a set of R888's for the rear - wish they made something to fit the front. R888's aren't the best track tire but the bulky sidewall allows them to wear better and of course at the airstrip they hook better than anything.
#85
Rohr tracks both the gt3 and turbo hard, I was surprised by the results
#86
check this out
https://www.youtube.com/watch?v=qxfgFkrtI_s
#87
#89
#90
