991 GT3 Wheels on a 991 Turbo?
991 Turbo
245/35 ZR 20 8.5J
305/30 ZR 20 11J
991 GT3
245/35 ZR 20 9J
305/30 ZR 20 12J
I have not been able to find the offsets for the OEM wheels to determine if 991 GT3 CL wheels will fit properly to a 991 Turbo?
I suspect not or I would have seen it done... who has the tech specs or can say for certain?
245/35 ZR 20 8.5J
305/30 ZR 20 11J
991 GT3
245/35 ZR 20 9J
305/30 ZR 20 12J
Received 1,543 Likes
I got offset info from the configurator last year when I researched before buying my 991TT.
Can't help with GT3, but here are two wheel sizes for the TT/TTS:
1-piece alloy wheels with 5-spoke Sport Classic design
9 x 20 ET 51 with 245/40 ZR 20 tires (front)
11.5 x 20 ET 56 with 305/35 ZR 20 tires (rear)
Alloy wheels with 10 double-spoke two-tone design
8.5 x 20 ET 51 with 245/35 ZR 20 tires (front)
11 x 20 ET 59 with 305/30 ZR 20 tires (rear)
From the configurator:
991 GT3RS
Tires (front)
9.5 J x 20 RO 50 with265/35 ZR 20 sports tires
Tires (rear)
12.5 J x 21 RO 48 with325/30 ZR 21 sports tires
If the GT3 has wheel wells as zaftig as the RS then I would very-much doubt GT3 wheels will fit a Turbo. But, doesn't the RS come with extra-plump corners? I dunno, but I bet the GT3/RS forum does.
991 GT3RS
Tires (front)
Tires (rear)
Interested in the GT3 CL (center lock) fitment. Sport Classic and 10 Double spoke are not CL ...both are 5 bolt fitments. The GT3 RS is a CL design but 21" rears clearly appear too large for fitment to a 991TT. Thanks.
Turbo S specs
9x20 ET51 245/35ZR20
11.5x20 ET56 305/30ZR20
GT3 specs
9x20 ET55 245/35zr 20
12x20 ET47 305/30zr20
The rears will protrude by 9mm which is OK because there are AM wheels that are more aggressive. The fronts however will not be so nice, they retract into the fender by 4mm.
GT3 specs
My Porsche dealer...who I attempted to buy GT3 wheels from...said that the front would not fit. If there was a way, they would have done it. I think the front are the problem, due to the offset diff between AWD and RWD.
Turbo S specs
GT3 specs
GT3 specs
GT3 RS front: 9.5" x 20", ET50
Could you go into more detail about the GT3 bumper conversion on the 991 Turbo? From what I understand the GT3 is narrower, but the GT3RS and Turbo are same width but not front fender width. But it looks like the GT3RS simply adds plastic flares to the ends of a GT3 bumper to match up with the wider GT3RS fenders. My heads spinning.
I'm assuming the GT3RS fenders > Turbo > GT3? Regardless the GT3 nose looks right at home on the Turbo and any 911 really.
I'm running bbs fi-r in gt3 offset, going to be switching to the 9.5 but the question is... will i be able to run a 265 up front or is that pushing it? sitting on techart springs.
The following 2 users liked this post by Oerding911:
JM DiFabio (02-18-2021),
Jpines07 (06-10-2023)
