Rear End Clunking
Rear End Clunking
Picked up a rear end clunk sound when going over speed bumps at low speed. Doesn't always do it and it just started last week. Shop couldn't find anything on first inspection and also was able to hear it. Anyone else experience this? It was an issue on M5s and turned out to be rear springs. It doesn't happen when at speed but will at low speeds and it's not consistent. It also seems to be in the left rear.
Mileage? Did the outside temperature change dramatically where you are?
Your question is a little vague, but I think with a bit more, we can help. My guess is nothing is radically wrong or the tech would have seen it ( I hope). That is why I am considering the mileage and local temp.
No, we are having milder temperatures, in the 70s instead of 90s now. Some 50s on some mornings but mostly 60-80 during the days now and it's got 10,500 miles. I though it might be related to the new ICs but I reached in there and and they are solid as a rock. It sounds like something bottoming out but there are no scratches underneath. They put it on a lift in the shop to have a look and nothing seemed loose or out of place.
My money is on the sunroof. It may not sound like it's coming from there but in these cars sounds travel. I had the problem in a previous 997 and it took forever to track it down and equally time consuming to properly address. If its what I'm thinking, and it sounds to me like it is, they should look there. I can give more detail if you like.
Open your sunroof and see if you still hear the sound?
If the sound goes, then it's the sunroof. I reserved an appointment next week for that. They said it takes two days to get it fixed.
991.2ts (02-20-2022)
ETA: That fixed it. Now even closed it doesn't clunk, maybe just opening and closing it readjusted something.
A quick forum search shows that these sunroofs on the 991 are certainly not without their issues.
Well I wouldn't have guessed that but I am going to workout in about an hour and the place where I workout has speed bumps that always produce the clunk so I will go through with the sunroof open and see what that does. However, if it's open and still makes the sound does that mean it's not the sunroof?
Yeah and I know it's not a sign of anything bad in the suspension. I am definitely going to drag race the car Friday night. I am carrying the proper tools to re-seat the Y-pipe to throttle body hose and tighten the clamp if that comes loose again but I didn't want to be worried about some strut failure or the like.
