Best exhaust for turbo noises
Like the title says, what are the best exhausts that promote turbo noise and over engine noise as well? Also has there been any companies that cracked the porsche ecu or gotten the car above 650hp?
Thanks!
Thanks!
100 CEL cats will give you the most Turbo spool noise. I won't name manufacturers because it's a big controversy about this subject,you'll have to research yourself.
Nobody managed to crack Porsche's ECU. There are tuning modules out there that are " fooling " it...
As for exhaust, Europipe has 100 cell cats. That is the exhaust I chose. There are louder exhausts on the market, however but that is not what I wanted. I wanted normal volume in normal and more sound in sport or sport plus at higher revs and, more importantly, freer flow for the GIAC flash.
The "search tool" is your friend when you apply the term "Best" to this topic...
Those of us who have invested in one of the various AM (after market) exhaust systems will have an opinion, and no matter how we try to objectify our comments... it's still a subjective opinion that's been beaten like a rented mule already on many previous threads.
Massively subjective and subject to fan boy 'ism re particular manufacturers,
but here is OEM cats and after market exhaust:
here is 200 cell cats, no CEL, and same after market exhaust:
The cats certainly add spool noise and "pops".
Agree the more reduction in back pressure from behind the turbo is the main thing that allows more spool volume.
OP the stock cats are 600 cel so obviously soak most of the spool sounds up. Now I have the EP system which uses the tri flow 100 cel cats. I found with the stock system the spool up was barely even audible on the outside. Inside with the stock always had that hushing sound letting you know the turbos were boosting up which was quite nice still, but now there is about 10% more volume to that situation plus the hushing element has a more of a crispness to it and, more of a distincter whistle to it now than what it had when stock. To describe the sound and spool differences outside the spool up is very audible now. You can really hear it easily. It is easily distinguished as a turbo engine now. Unmistakeable. Volume wise on the outside it sounds much like a 991S with the PSE on, but with a lot of turbo whistle going on. It sounds hot. There is no doubt it is a Porsche engine too and not some other car. When you apply throttle inputs the turbo spool becomes even louder. It will bark on the outside more than a pse (maybe 20% louder I think...or could be a bit less) at wot and has a great combo of exhaust sound and turbo whistle.
Edit: Sorry don't have a sound clip. Not really a believer in those anyway in so far as making an accurate determination of how the cars sounds in real life. One day I will make one when I get the time.
