Hissing Throttle
Hissing Throttle
I have a 2015 Turbo S. 200 miles on it. As I drive it I hear what can only be described as an annoying "hiss" for 2-3 seconds when I let up on the throttle.
Even at low speeds, (or from a stop, for that matter), I step on the throttle, speed up to 20-40 MPH, and when I let off on the gas I can hear "hisssssss." It sounds like a vacuum sound, perhaps. I can do it every time.
Anyone have an idea what this may be? I will take it into the dealer in the near future, but it annoys the heck out of me for now.
This is why the TTS comes standard with the Burmeister.
Turn the volume up just a bit.
Problem. Solved.
Problem. Solved.
The 991 Turbos are very complicated machines.Get use to the noises and enjoy them ,that is what I did.If you do not have a CE Light and the cars runs good don,t worry about it....
They are also very smart,it their is a issue,it will tell you...
