Sponsored by: Road Spy
Steel rotors for ceramic TTS?
Old 05-09-2014, 08:37 PM
Canyonrs4
Canyonrs4's Avatar
Default Steel rotors for ceramic TTS?
Does anyone make a steel rotor replacement for a 991 TTS with ceramic brakes?
Doing some track time with a TTS (991) and the cost of ceramic rotor replacement is just silly. I have not found a replacement for the huge ceramic rotors on the TTS wondering if anyone has made a set yet?
Old 05-12-2014, 09:41 AM
RCMA991
RCMA991's Avatar
Have you checked to see if the 991 GT3 steel rotors will retro-fit the TTS ?
Old 05-12-2014, 11:34 AM
Canyonrs4
Canyonrs4's Avatar
The issue is the stock iron rotors are 380mm front and rear on both the 991 GT3 and TTS while the PCCB rotors are 410 mm front and 390mm rear (it appears that both cars share brake components). If I wanted to use the stock calipers I need to match the rotor sizes and also find proper pads too.
Old 05-12-2014, 09:55 PM
Canyonrs4
Canyonrs4's Avatar
Update: Girodisk has offered to take a look at making a set of replacements... I need to send them a pair of front and rear PCCB's to "reverse engineer" a set of iron rotors... how many folks would be interested?
Old 05-13-2014, 12:31 PM
FastLaneTurbo
FastLaneTurbo's Avatar
At $25,000 for Replacement Ceramic Rotors and Pads installed vs $2,500 for Steel Rotors and Pads you are
certainly on the right path if you want to track your car. I checked with Suncoast Porsche Parts in Florida.
and they do not know of any existing Conversion kits therefore, Calipers, Rotors and Pads would have to be changed to accommodate the change to steel. Costs could be close to $10,000. I vaguely remember PAG
saying they would be offering a Steel Rotor Conversion Kit when they first announced the Turbo S so perhaps you could check with PAG in Germany since most dealers I've checked with know nothing about it.
Old 06-06-2014, 10:12 PM
Stuttgart786
3rd Gear
Stuttgart786's Avatar
Hey CanyonRs4,
I bought a 2014 991 turbo back in february and I just switched over to the PCCB Ceramic brakes. I originally had the Brembo 991 steel brakes that came with the car and I'm actually selling them. They are in great condition with about 1500 miles on them. If you are interested please give me a call at 3106140818.
Here is the link to my ebay posting http://www.ebay.com/itm/231250243413?item=231250243413&viewitem=&vxp=mtr
Old 06-07-2014, 05:38 AM
speed21
speed21's Avatar
^ The ceramics on the TTs are insane good. Don't blame you for changing the steels. That said the steels are no doubt the more cost effective for track use. Be damned paying 20K to change rotors if they wear out on the track.
Old 06-08-2014, 10:26 PM
allans
allans's Avatar
Are these brakes still available? Sent two PM's -no answer?
Old 06-10-2014, 03:27 AM
Stuttgart786
3rd Gear
Allan, if you are referring to the brakes I posted, please give me a call at 3106140818
Old 11-30-2014, 02:24 PM
RacingBrake
Former Vendor
RacingBrake's Avatar
Default 991 Brake Kits Option Update
CCM (pccb) Rotor Replacement kits:
http://www.racingbrake.com/RB-Calipe...por-irp-01.htm
Iron (standard brake) Rotor Replacement Kits:
http://www.racingbrake.com/RB-Iron-R...por-irk-05.htm
Quick Reply: Steel rotors for ceramic TTS?
