Tyre pressure monitoring
Hi please advise...I am ordering a set if rims for the tts,for track day use...what do I need as the car has tpms for it to function with the new rims...thank you in advance..
Hey YellowMan, you'll need to purchase a second set of TPMS sensors for your track rims. You can order a dealer set...or you can try your luck with a high quality aftermarket set. I have seen some come through our dealership that were truly plug and play. What ever sensors you chose, you'll have to "adjust" TPMS in your TFT display and take a short drive...maybe 100-200m over 25kph and the new sensors will pick up pressures and update them on your display. Hope that helps.
