Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   991 Turbo (https://rennlist.com/forums/991-turbo-230/)
-   -   Launch customer who is not pleased... (https://rennlist.com/forums/991-turbo/774781-launch-customer-who-is-not-pleased.html)
carcommander 09-21-2013 07:47 PM
Originally Posted by Rennteam (Post 10776547)
Patching/plugging a tire is OK for emergency situations but you need to keep the speed down (50 mph max. speed is recommended) to be safe and I wouldn't go for longer distances with that tire. This should be fast enough to get you anywhere close to a Porsche dealer or high quality tire shop.
I have patched and plugged many tires myself. I have seen them last the life of the tire. As I stated above I would replace the tire ASAP. A plug can be installed in about 5 minutes.
FastLaneTurbo 09-22-2013 03:44 PM
I also carry a plug kit in my Porsches, and a collapsible spare if available - also tools, jack and compressor.
(Yes, I am paranoid - but have had many flat tires caused by both road and track hazards plus vandalism) Plug kit works with nails, vandals tacks and small punctures. But useless if tire is Cut.
carcommander 09-23-2013 10:09 AM
Yes, if the tire is cut you are on a tow truck. I factor in the lack of spare in which of my vehicles I take out of town. I bet 50 percent of drivers can't change a tire even if they have a spare.
© 2019 MH Sub I, LLC dba Internet Brands
