Boost sensor locations
Hey all, can someone point me to pictures or diagrams of where the two boost sensors are on the car? One is near the throttle body and the other is on the manifold, but I'm not sure where. Also, part numbers would help since I have to probably replace them.
Originally Posted by biff0rz
(Post 18277737)
. -Payam |
Originally Posted by BMS
(Post 18278733)
One is on the charge pipe (Y pipe) near the throttle body as you stated. The other is on the top of the right manifold (If you're looking at the engine from the back of the car).
. -Payam |
(Post 18279048)
Thanks. Do you know if they are the same part number? Also...any guide on how to reach the one on the manifold?
https://www.n54tech.com/instructions...tall-Guide.pdf -Payam |
(Post 18279153)
From what I remember they are the same part number. Here's our JB4 install guide which should hopefully help you.
