Tips on removing cats
Hi all, about to change my exhaust. Anyone have tips on removing to top nuts on the cats? Does everyone replace the gaskets from cats to turbos?
Bud
Bud
I think I just used a swivel socket. Couldn’t have been too bad as I just had rotator cuff surgery before I installed the Kline.
usrodeo4 (02-12-2020)
If you have a dremel use a carbon tip grinder to remove some of the material under the nuts...enough to get a thin wall socket or open end wrench on them. Only need to grind a little to get them off
just buy some more tools like circular box end
12mm wrenches
you can do this simply with the right tools no cutting required
And yes I’m very very serious LOL
I have installed several 991 TT exhausts and never had to cut/hack anything away..
The last 991 TT exhaust that I installed (tubi w/cats) I did on a lift while wearing a Button down with a half zip sweater and did not even remove the bumper..
Really straightforward install with the correct tools
I second that..
Worked for me! I used every type of wrench and/socket out there including crow foot open end wrenches. The design of the cats I had simply did not allow anything to fit around the nut in order to loosen it, and with the heat the cats produce it was tight. The copper/brass material on the nuts is soft as it is. Didn't do any hacking or cutting although I thought about using a nut slitter I just removed enough material on the housing under the nut enough to fit a thin wall socket on. Good luck Op...hope yours is as easy as finding the right tool...mine wasn't.
I was also a Z06 owner and ZR1.
