Knocking Noise from Back of 911 ,991 Turbo S 2015, 8,500 mile,
7th Gear
Whenever the car turns left or right right you can clearly hear a knocking sound (the car is driving at low speed) coming out of the right rear suspension. I looked under the car and nothing looks loose or out of place on either side. Please note that the car does have rear-axle steering.
Received 5,416 Likes
Center locks properly torqued?
I had a similar noise on delivery of my car. It spent the next week at the dealership before they removed the rear bumper cover and found one of the mounting brackets was cracked. Noise resolved after that was replaced.
7th Gear
i do many launch control and when you take the car from ZERO TO 60 in 2.7 seconds, the back suspensions go all way Dow and May take sometimes to go back to the normal position of the PDDC , PORSCHE DYNAMICS CHASSIS CONTROL do not reset or hold the suspension on a position that when we pass over any road undulation make the crazy noise that we can hear very load.
in my case, the noise , I no longer hear and I did nothing to fix.
I do do not know, I am just an engineer and what I am explain above “ was only a think, I do not know 100%
thank you to offer me some help
7th Gear
Porsche 911 back suspension knocking noise
in my case, the noise , Is no longer there and I can not hear anymore and I did nothing to fix. I do not know, I am just an engineer and what I am explain above “ was only a think, I do not know 100%
local Porsche dealer has no idea or suggestion.
Correct! I have the 911. 2015 turbo S, 991 and happening the same way you explaining. I believe in my case that I do many launch control and when you take the car from ZERO TO 60 in 2.7 seconds, the back suspensions go all way Dow and May take sometimes to go back to the normal position of the PDDC , PORSCHE DYNAMICS CHASSIS CONTROL do not reset or hold the suspension on the lower position that when we pass over any road or undulation make the crazy noise that we can hear very load.
The noise is only slow parking speed maneuvers..My car was lowered on H&R springs.
Champion hears it and has gone through the rear suspension from the bottom and found nothing loose.
They now want check the top shock towers which must get to from rear interior to get at it.
I will report what they find.
Elliot
I have not launched my car {2017 TT.}
Elliot
Elliot
