displaying posted speed limit on 991.2
So I noticed I'm not seeing the posted speed limit on the tach like I did with my 991.1
I did an online search and noticed rennlist user StormRune found it on the PCM. So on the 991.2 it is displayed, if it's enabled, on the map screen.
It makes no sense why they moved it to the PCM, which requires you looking at your speed on the center cluster, then looking at the map screen on the PCM. Very poor engineering IMO.
To enable it on PCM, press MAP button, then OPT button, go to General Settings and enable "show speed limits"
On several on my new cars the speed limit can be put into the heads up display, and you know the speed limit before you even see the posted signs on the road, nice to have
