View Poll Results: What would you buy if price and miles were comperable
2017 Turbo
48
64.00%
2015 turbo S
27
36.00%
Voters: 75. You may not vote on this poll
991.1 Turbo S or 991.2 Turbo
That is a very tough question.
As An alternative, I might also consider buying the 991.2 Turbo now, and later adding a COBB AccessPort or other, and tune. That would be faster than the 991.2 Turbo S.
JMHO...
JMHO...
he'll tune either or. I'm just wondering if the .2 improvements are significant
for non-performance related, very minor stuff - really like Apple CarPlay functionality in the .2 PCM, also the manettino toggle thing on the steering wheel is cool lol
Received 3,364 Likes
As the old adage says, always buy the newest you can afford.
Rocky Mountain High
It depends on the options that he wants. If he wants it really decked out with options (centerlocks, PCCB, PDLS+, PDCC, etc., then the TTS is the way to go.
Rocky Mountain High
No. The TTS is more of an options package than anything else. You can option a Turbo with all the things that are standard on a Turbo S, but it will cost more than a Turbo S. The Turbo S includes PDCC, PDLS+, 18-way adaptive sport seats, leather backs on the sport seats, and much more.
I don't think there is much, speed wise, between the two of them. Frankly, I don't think there is much between a TT and TTS of the same generation. At least legally. I used to own a .2 TT and it was stupid fast.
Newer car = longer warranty and less wear. That's a good thing.
I do think the .1 is a better looking car than the .2. The newer Turbo has a longer, more pointy nose and a bigger turn signal unit.
I don't want to over simplify - but from a performance perspective the 991.1's are easier to modify - simply because you don't have to remove the ECU and ship it to your Tuner. So if you are modding - I would go with the 991.1 - and you get all of the Turbo S hardware.
That said - I voted 991.2 Turbo (although the prices are pretty close depending on your upgrade list for a lightly optioned 991.2 Turbo S - more on that later).
The reason being that if you are keeping the car - you want to go with the latest iteration - especially with the 992 already out. Modding will catch up - someone will crack the ECU - and you get the .2 upgrades in the process. The 991.1's turbos are the same for both Turbo and Turbo S - so the modding path is the same - as it is for your 991.2 Turbo.
THAT said, you only live once - and the 991.2 Turbo S turbos ARE different for the first time. Not massively - but they are different. When I priced out the two cars - especially when adding CCB's to a Turbo build - they were within 9K Canadian (so 7Kish US) with the same options. If you can squeeze it out - I would go Turbo S - 991.2. If not - 991.2 Turbo.
Let's not forget 991.1 and 991.2 are both great cars - so you can't go wrong either way.
Good luck!
Good luck!
