Sponsored by: Road Spy
Kline Innovation 991TT Exhaust Program
Old 03-28-2019, 07:47 PM
VividRacing
Former Vendor
VividRacing's Avatar
Default Kline Innovation 991TT Exhaust Program
Hey guys! We are offering the best pricing on one of the best exhaust manufacturers for the 991TT; Kline innovation. Kline is a Romanian based company specializing in stainless steel and Inconel exhaust systems for high end autos. They are known for being extremely high quality, high performing, and great sounding. The 991TT is one of their most popular platforms, offering a stainless or Inconel system with various options such as completely decatted race systems, or 200 cell high flow catted emissions friendly setups. If you are looking for an exhaust system that does not give you excessive drone when cruising, but really screams when you punch it, Kline is your solution. PM or email for any inquiries, we are offering amazing pricing for Rennlist members!
Capitalising on the design innovations and success of our 996 and 997 range, the starting point for designing the 991turbo exhaust had been set high. Our trademark perfect x pipe geometry, harmonically tuned silencer geomtery, Inconel 625, and our proprietry acoustic silencer packing materials result in a system that has become famous for that perfect sound. Zero drone, and a raised pitch raucious incindiary howl in higher rpms and hard throttle. The design is so perfect, that you can even run catless versions silently at cruising speeds, only unleashing that howl when you drive the car hard.
During development there were some clear evolutionary design steps that we could incorporate. The secondary tail pipe allowed us to integrate an effective gas overflow system. The concept was conceived at the fluid dynamic modelling stage, and effectively works to cut low rpm noise, while allowing an effective increased cross section at higher rpms producing a more accentuated Jekyll and hyde personality, and slightly broader torque curves.
De-cat cross section 70mm OD specifically chosen for a balance of peak torque and power.
Silencer section, cross section 65mm OD and 44mm OD overflow
Catalysts come in a variety, from 108mm OD to 127mm OD
Turbo back system
Available in standard 304 grade stainless steel, weight 14kg 200cell cats, 12.5 with de-cat
Inconel 625 formula one grade material, weight 7.5kg
Titanium G2 silencer section is also available, weight comparable to Inconel
Standard 304 grade stainless, weight 6kg total
Inconel 625, weight, 2.9kg total
Titanium unable to endure extreme heat
https://www.kline-innovation.com/wp-content/uploads/2018/01/Porsche-991-Turbo-10.jpg
VividRacing is offline
Quick Reply: Kline Innovation 991TT Exhaust Program
