Turbo S tire rub
Turbo S tire rub
Have a 2015 Turbo S with tires that rub when turning fairly sharply for parking and low speed maneuvers. Stock OEM tires inflated to comfort levels. Most of my P cars have done this, but was wondering if this is pretty common on these particular cars and whether small alignment changes could help. I found with my other cars that lowering the inflation helped sometimes, but not the case here. Thanks.
Believe it or not, my dealer calls it camber scrape.......happens when it is colder outside or surfaces are wet or icy when you turn the wheel almost all the way.............totally normal, but weird.....................my 993 and 996 C4S did not do this........
