Roll Cage Color !?
Hi guys,
In order to continue using the car for private track rentals, NHRA demands a 4 point Roll Cage in my Turbo S. My car is White with red interiors. What color do you think looks the best on the roll cage with this color combination? https://cimg2.ibsrv.net/gimg/rennlis...c9fc310497.jpg |
https://www.racepagesdigital.com/ten...by-nitto-tire/
Are you running quicker than a 10.0 or more than 135mph ? If not, the official is using the old rule book ! If you are, you will need a 4 point roll bar bolted in plus a swing out door bar with the 5th point bolted to the floor at your left foot. Good luck ! |
White roll Cage.
I don't think any off the shelf roll bars are NHRA spec. From my understanding, NHRA requires fully welded 5 or 6 point roll cages, none of the main bars can be assembled with bolts. Maybe the track official might turn a blind eye as long as he sees some kind of roll bar?
Yes, the car ran on a test run 9.51 at 145mph. Here in PR, they accept a 4 point roll cage. So I’m going to do a bolt-on one but don’t decide on which color to chose. |
Originally Posted by Harry Da Hamster
(Post 15643614)
Originally Posted by pr-s
(Post 15643619)
Black is stealth.
I say black as well. |
Originally Posted by neil.schneider
(Post 15646085)
White roll cage with red leather padding, I am going white roll cage with white leather padding, but then I don't have red interior.
