Proper method to lower motor
Hey guys I’m a new owner of a 991 turbo and for maintenance purposes spark plug changes it’s Cetera I am looking for the proper method and steps to lower the motor a couple inches or so thank you in advance Mike ps. On my old 996 turbo motor you could just Support it from the engine case |
We need a DIY for this!
I was scared to do this when I did the plugs and just worked around without lowering the engine and it was a hell of a tough time. :surr: |
Originally Posted by mikerosi
(Post 15635994)
Hey guys I’m a new owner of a 991 turbo and for maintenance purposes spark plug changes it’s Cetera I am looking for the proper method and steps to lower the motor a couple inches or so thank you in advance Mike ps. On my old 996 turbo motor you could just Support it from the engine case confused on exactly what I should use under the oil pan Since I don’t have a tranny jack |
(Post 15636475)
Hi thank you for that come back I’m still a little confused on exactly what I should use under the oil pan Since I don’t have a tranny jack |
Originally Posted by onfireTTS
(Post 15636840)
Tranny Jack would be best for the weight involved.
Thank you for that |
You dont need a transmission jack. Assuming you are using a quick jack or jack stands to raise the vehicle, just a hydraulic car jack with a piece of plywood or 2x4 to support under the oil pan is all that is needed. Then follow the directions I posted above. Make sure the plywood is large enough to support the enitre oil pan. I have done this on my 991ttS many times with no issue. |
Originally Posted by Jay993turbo
(Post 15650023)
... I have done this on my 991ttS many times with no issue. |
