Anyone else struggling with the Turbo S engine noise?
Ducaiti999 (01-24-2021)
#32
My 14' never droned stock. I just added the Kline Inconel exhaust with cat deletes, still no drone at any rpm. Weird.
#33
I have a 2015 TTS and I agree there is an "unpleasant audio frequency" in 7th gear at cruising speed. I just assumed it was part of the Porsche 911 experience since this is my first one. I usually drive in 6th gear to avoid it. It was present with both stock and aftermarket exhaust.
#34
I hate the symposers. What a bad idea... As for droning, I never noticed it in my '14 TTS. That said, coming from 3 NA 911s, I sure feel the difference in the way turbo sounds and it is not to it's advantage.
#35
Turbos sound better than they used to, but not as raw for sure......unless you spend some $$$ on aftermarket exhaust stuff.........
#36
I have some drone in my 2014 TTS at lower RPMs. It gets considerably worse in cooler outdoor temperatures (cooler meaning 50 degrees F or lower). For me, the drone is much more noticeable from the passenger seat versus driver's seat.
I don't notice the drone nearly as much at freeway speeds, but I drive with Sport on and don't dip into 7th gear as much.
#38
I've tried for two different days to listen for any drone. I've tried at the recommended speeds and RPM's and I can't detect anything except tire and road noise. Both easily drowned out by the Bermeister. Now full disclosure, I've disconnected and capped my sound symposer at both ends, soundproofed my doors (huge improvement) and some minor soundproofing of the rear wheel wells.
#39
That is great. Would you be able to tell me some details on how you did the door and rear wheels please? What soundproofing product did you use?. There are a number of them on the market. I am going to do the same on my 911 S.
thank you very much
CB
thank you very much
CB
#40
I’m not sure the suggestion for a different car was condescending. The TTS (mine is an 18) is by far, the quietest of the pcars i’ve owned. That’s not to say it’s quiet... it’s noisy. Too noisy to comfortably take calls, but not so noisy so as to bother me. In fact it’s rather on the boring side sound-wise, hence all the threads on here about aftermarket exhausts, etc.
#41
I read and watched dozens of reviews of the 991 TT/S and many did say it was on the loud side which did concern me. They often put that down to noisy stock tires, but that kind of indicates that Porsche let soundproofing slide even though they knew that reviewers thought it was loud. I ordered one and hoped it wouldn't be too bad, and expected there might be additional measures that could be taken to quiet it.
So I'm also very interested in your soundproofing details, and glad to learn about the symposer that can be defeated..
#42
I do find there is a boomy sound, granted stock its not too bothersome...SO... I'm actually working on a resolution for this with Fabspeed motorsports right now and are targeting that rev range specifically. with our cars, the only catch is this solution wouldn't necessarily be quieter, it actually will be louder in the higher revs, but down low in the drone should be totally cancelled out or as close as you can physically get... Happy to tell you what's cooking if you're interested!!!!
#43
I'm the opposite. I find it to be a little too quiet. In normal mode and soft shocks - i can comfortably speak on phone and drive long distance. But then again i am coming from a 997.2S w Tubi and a Lamborghini. i do find the TT to be "boomy" in Sport. But w my Cobb tune - normal became sport and its not boomy.
I dont find this condescending - but if you want quiet - a Porsche 911 is not the best option. Panamera maybe. Mercedes etc. A Porsche 911 is sporty. TT is GT but much closer to sporty than a Bentley.
I feel people buy something and try and make it something else.
#44
Thanks to wru and rodsky for validating my post of 1/22. It was not meant to be condescending. I still don't understand why anyone would purchase a high performance Porsche sports car and then complain that the engine is too loud.
#45
The complaint I made was that at a very specific rpm, around 2000-2200 rpm, at very light throttle, there is a boomy drone in the car. The same complaint many others have made, in this thread and others.
Does that sound like I am making generic complaints about loud engines? No. Your whole point is a strawman.
This is my third 911, including a 2014 TTS and a 2017 Carrera S and while both were noisier than my two corvettes (2005, 2009), my two M3s (2001, 2011), and my M5 (2014), none of those cars had this boomy drone.
Why can't someone ask about a legitimate issue on a car without people coming out of the woodwork claiming either there is no problem or that I don't know enough to buy the appropriate vehicle?
