Sponsored by: Road Spy
The 986whp 991TT build you've never heard of, until now!!
Old 02-05-2019, 01:11 PM
bojote
bojote's Avatar
Centerlock Wheels w/ Fresh Toyo R888R Tires, 265/315 widths
265 Fronts? I believe you meant 255's right?
EDIT: There's no 265s in 20', so safe to assume fronts are '19.. my bad
Old 02-05-2019, 10:05 PM
pr-s
pr-s's Avatar
Originally Posted by CSF Cooling
Update on the car - new parts that just came in from the UK.
Here is the 1st set in the USA (prototype set) from my friends at Eventuri Intakes.
Beautiful piece of engineering which will look good, and will hopefully perform well as well! (I have no doubt, my friends make some awesome intakes!)
The way these intakes look, I might just have to run with no rear bumper!
New Carbon Fiber Intake for 991 Turbo / TurboS - fits both 991.1 & 991.2 systems
WOW! those intakes looks really really good! will do you a before and after with numbers? Any butt dyno or sound improvement?
Old 02-05-2019, 10:07 PM
BMS
Former Vendor
BMS's Avatar
I doubt any gains to be honest, maybe sounds. From my testing the restriction is the actual inlet to the turbo and the pancake piping.
Old 02-06-2019, 12:05 AM
Ttz06vette
Ttz06vette's Avatar
Any idea if/when The inkakes will be available and pricing?
Old 02-07-2019, 12:05 AM
neil.schneider
neil.schneider's Avatar
Art!
Old 02-11-2019, 05:55 PM
CSF Cooling
Basic Sponsor
CSF Cooling's Avatar
Wheels incoming!!
Yokohama Advan GT Premium (CenterLock)
Front: 20x9.5 +45
Rear: 20x12 +44
Racing Titanium Blue with machined ring
will be going on some sticky Toyo R888R's
http://www.CSFrace.com/
Old 02-22-2019, 06:50 PM
CSF Cooling
Basic Sponsor
Wheels were delivered today - Yokohama should really update their stock photos across all of their sales channels - no way do they do justice to the actual wheels. these things are drool worthy!
I can't wait to get these on the car!
Old 02-23-2019, 01:19 AM
kouzman
kouzman's Avatar
They look amazing. I am waiting for my set for another month or so.
Old 02-23-2019, 03:53 PM
Nanook
Nanook's Avatar
Wheels incoming!!
Front: 20x9.5 +45
Rear: 20x12 +44
My Advan dealer suggests sizes as follows:
"20x9 +49 front and 20x11.5 +55 Rear which are pretty much same with your OEs".
How did you determine the size you purchased and which offers more (better) offset ?
Old 02-24-2019, 02:29 AM
CSF Cooling
Basic Sponsor
1) Aesthetics - I like proper fitment with my wheel setups, so a little wider is preferred for my taste (i.e where the end of the fender lines up with the end of the tire flush or the tire/rim pokes out just a little bit pass the fender) Plus a good suspension drop to get rid of any gap in fitment between tire and fender.
2 Function - I need the widest tires / wheels possible that I can fit on the car (w/o rubbing of course) for 1/2 mile racing at the speeds we're attempting to go (high 190s / possibly 200 mph). I wanted to go 21 inch, but Toyo only makes the R888R in 20's. Although 21's would look epic on the car, 20's is the best choice to hook the power / get the traction I need... Toyo R888R + 20 inch wheels with 12 inch width is the way to go if you're trying to do what we're doing. Also, others I have talked to who do road racing also have 12 inch rear tires.
Others on the forums might be able to chime in on their wheel sizes / offsets for their aftermarket wheels.
Old 02-24-2019, 09:44 AM
Nanook
Nanook's Avatar
I agree with your comments...so your sheel size will bring the outside face of the wheel closer to the outside fender plane ?...I prefer that !
Any pics mounted yet ?
Old 02-25-2019, 12:51 AM
Jean
Jean's Avatar
Using 9.5” in the front will fit 265s better, with larger footprint than if you fit them on 9”. The ET45 In 9.5” will extend the wheel 10 mm to the outside, the way I like them too, perfect fit for the 991 turbo.
With that being said, you don’t want to go wide up front for a half mile target, you’re increasing rolling resistance and aero drag somewhat.
Old 02-25-2019, 08:33 AM
Nanook
Nanook's Avatar
All good info thanks
Old 03-04-2019, 09:06 PM
CSF Cooling
Basic Sponsor
Thank you to Scott @Antigravity batteries for jumping on board to support our project car.
Both Sam at EvoMS and myself were super impressed with the weight savings and construction of the battery.
Stock battery is 59lb.
Antigravity is 16.4lb. (42.6lb / 72% lighter than OEM)
- ​​​​​​Also comes with wireless fobs to turn it on if it shuts itself off due to low voltage.
We received their H6/Group 48 car battery with 40ah
- We decided on the 40ah, even though it's slightly heavier than the other choices available, because of our particular demand we have for the battery on this car is to have enough reserve to allow us to make changes to the ECU while the engine is off. In order to review datalogs and make tuning changes, the car sits with the ignition on while plugged into a laptop for 5-10min at a time. During this time the whole car is powered including the fuel pumps and occasionally cooling fans running drawing quite a bit of power (20-40a) on top of all the other normal loads the car has (HVAC, dash, radio, etc.).
Here is a link to purchase (jump on it now) limited availability - https://shop.antigravitybatteries.co...tive/ag-h6-rs/
Old 03-04-2019, 09:13 PM
kouzman
kouzman's Avatar
so the H6 is a direct fitment to the 991TTS?
shoot me a PM guys where to find your authorized dealers for your intercoolers!
Quick Reply: The 986whp 991TT build you've never heard of, until now!!
