P/N Request for OEM GT2RS Water Spray Tank
I should get a GT2RS intercooler group buy going.. Jean you are correct about the price increase. Once the sales volume numbers go up Porsche raises the price!
No I am using larger aftermarket ICs and meth, IIATs are good, but I will go back to stock coolers and meth next week, they work better for the track/circuit.
Good idea if you can negotiate good price and enough stock from the suppliers. Tuners will buy stocks and prices will be pushed up, I saw this with my 997GT2RS, when I needed replacement ICs, price had doubled.
I have 3 comments here:
1. My 991.2TTS had way bigger top speed at the end of straight lines after upgrading to big ICs (same tune, quite same conditions) - maybe from 152mph to 157mph on average, I have no logging device, but from vbox and even harry laptimer I can clearly see that.
2. Speaking of regular oem Gt2RS coolers, the 991 Clubsport GT2RS is using even bigger ICs from the factory, so my guess is OEM coolers arent going to perform better than aftermarket.
3. If we do meth, should work even on stock coolers, as meth is so efficient, maybe you can keep the big IC and just add meth, just my opinion..
What I have now is larger IC with meth, I have been tracking very hard Porsche turbos for over 15 years and collecting gigabytes of data, I wouldn’t be swapping back if I didn’t have valid reasons.
Larger GT2RS cooler has different fin density than (almost) all of the aftermarket coolers being sold, and has been developed and tested by engineers with unlimited funds and tools. They would have picked up an off the shelf commercial 4.5” IC if they were looking to develop a car for one straight line run at top speed. I haven’t seen evidence that the Clubsport version uses larger ICs, but might be true.
Circuit racing drives your temps to super high levels after one single lap, and the lowest temperature they drop to in the next lap keeps getting higher and higher and never recovers, as long as you are running at full throttle, so minimum and maximum temps keep increasing.
High speed runs runs, due to big airflow, will start dropping your IAT at higher speeds after a peak somewhere along the run, plenty of data available.
I will post data to prove my point when I get a chance and test.
I'd like to add some other considerations I need to learn more about on the TT platform before mapping out my own upgrades for road course tracking.
IATs can be lowered by doing modifications that improve the engine's volumetric efficiency, which in turn allows the turbos to run at higher efficiency, which means they provide their boost while generating less heat. Intercoolers designed with less resistance through their cores (less pressure drop) achieve that, as does improved flowing intercooler piping, throttle bodies, as well as the turbine sections of the turbo chargers. The design goals of the 991 Turbo were more for street use where shedding constant high IAT causing boost wasn't the important factor that it is for the 991 GT2 RS. So where the Turbo's IC's surely do a decent job for their intended use I would trust the factory's RS intercoolers to offer the best results under road course conditions over aftermarket offerings that provide dyno test data that is meaningless under road course use.
I already know that water/methanol injection directly into the intake ahead of the throttle body is by far the most effective way to lower IAT's, and likely so much so that the particular intercooler, intake pipes, TB and turbines used become less critical. But what I don't know is how restrictive some of those other components are at stock boost levels, and if replacing them provides enough benefit to warrant the effort and cost if using methanol injection. I suspect the use of methanol injection would not even require a change in tune, making it not only the most effective way to reduce IATs, but also among the simplest.
Bruce
Bruce
Jean
i agree with you. I had initially installed many upgrades on my car to then find they weren’t great for circuit racing. Most upgrades out there are ment for straight line racing.
I know that Mike at TPC is been working on several products for the Turbo mostly focused on circuit racing rather than drags strip. We are currently stripping my car of many of the previous upgrades and redoing everything again. From software, suspension to cooling. Your data would be invaluable.
Bruce
Bruce
One finding while using meth/water injection is that the intake charge stabilizes at some point during a run (slows down the temperature increase pace) however on a circuit, it does not prevent temps from keep going higher. I have been against the use of Methanol with every turbo iteration I have had, but new management systems and the evolution in technology has made it so safe and efficient, and I am currently very happy with its use. I have yet to prove any lap time improvement with it, if not marginal though. First straight line run when methanol is injected into the port at a certain preset boost level, you will clearly see your IAT stabilizing if not dropping a bit, but after a few turns and ongoing load, the effect is not at all that clear.
The GT2RS spray system is however not only boost dependent, like a meth system or other aftermarket IC water spray, but RPM , engine load and IAT together.
TPC have road race experience with turbos through Levitas racing his own 991 turbo, I am sure they must have some good learnings.
The chart below from my own data shows almost 2 laps on a rather small track, see how clearly the IAT keep increasing in straight line, this includes methanol and a large IC tank.. The time it takes to cool down the larger heat sink is fundamental in road/circuit racing to keep the power in the next straight, you can see temps barely decreasing in the braking zones down from 160mph.. expect 70-80HP drop between first and second lap alone, and much more subsequently on a modified turbo. The thermodynamics at play are on another level from any 0-200mph single run. And by the way, timing being pulled is minimal if any, across the runs.
4flynlow (02-16-2020)
Well Jean, that's good information but rather sobering data. In post 17 you said that IATs were good with your larger ICs and meth injection but a loss of 70-80 hp seems huge (and caused by lower air density if timing wasn't being pulled). I know you've carefully optimized your whole setup to manage IATs. Btw, what would the boost levels have been in the upper range on these runs?
Mike is a talented engineer and experienced builder but he's fighting physics with very few options it would seem. Combining an IC spray with methanol injection would be one obvious option but not sure what else would be practical.
Thank you for sharing your track knowledge and experience in these various threads! And let me know if I should cancel my TS build for track use...or keep it as a stylish winter beater and keep tracking the Viper TA, lol.
Bruce
Bruce
Bruce
Bruce
IATs are never good, they are acceptable when your timing is behaving reasonably. Boost between 25-28PSI depending on runs.
Point to take here is what I have been saying for years, all the IC theory and cooling and datalog arguments related to dynos, benches and straightline high speed runs are completely irrelevant once you hit the track in crazy mode and you see the real test. The difference in load and engine stress is exponentially higher.. This where Porsche excels, take a GT2RS and lap all day and you will have sustainable performance throughout, reason why they don't extract crazy torque or HP from their stock engines, and everyone thinks tuners know better how to get power out of the platform. They cater for track cars as well as daily drivers.
Good luck with the Viper, I run against them every time, TA and ACR Extreme, if you think 991TT heat build up and HP loss is bad, Viper's are insane!
Sidetracked this topic, apologies to OP. I guess the part number question was answered at least
Hopefully this discussion will be informative for some of those who might be considering the RS spray system to address IATs.
Your first plots in post 25 show how temps increase steadily under continuous and prolonged full throttle loads from low to high speeds, with very little recovery time in-between which is the most demanding scenario possible. That won't be the case for many road course configurations, and thankfully not my home track, Mosport, or Mont Tremblant where some of the fastest local Porsches come to play. Vipers do lose power as rising IATs cause timing to be pulled, but even still logging pretty consistently shows my best times closer to the 8th lap, more a function of my lapping day driving style than anything else.
Your plots in post 27 look more encouraging with IATs recovering well during periods of partial load which will be more typical on local tracks. I hope to be satisfied at stock boost and power levels and will look to IAT management, tires and suspension for improved performance. And speaking of which, I had a chance to compare Mike's TA to my own, and a pro driven ACR-E, at a track in New Orleans where Mike had his DSC/Tractive dampers installed with Hoosiers and those transformed the car more than I would have thought possible. It'll be interesting to see what he comes up with for IATs on his TT build!
Bruce
Bruce
First I will start to say that I respect you Jean a lot and your knowledge, I was reading your posts here and on 6speed (I am Fadi on 6speed), but for this time only I have some concerns regarding what was posted above.
Running 25-30psi on tiny vtgs means a lot of heat buildup, for sure 991gt2rs turbos will help A LOT as they have huuge hot side. If I remember right even 991.2 tts has bigger conpressor wheels but so bigger turbine wheels. Even for the bigger turbine wheels I would say 1.8-2bar is way tok much... thats gt30 turbine suze boost to deliver excellent results. My guess is 1.45-1.5bar and overboost of 1.6bar should be the sweet spot for regular 991 turbos using meth.
So running 1.8-2bar on vtgs is for sure out of their efficiency and will delicer HOT air, even on slighlty bigger upgraded ones, and upgrading just the conpressor wheels will not help. Do you have any dynos or 100-200 at 1.6bar compared to 2bar for example? My guess is the car will do only more torque but no more hp.
Another thing to consider is how the measurements were done..
- I know you race in very hot weather, I see even from the initial IAT at idle, so temps recovery will be quite different in respect to outside temperatures. Please take into consideration that OEM gt2rs clubsport is using bigger ICs very similar to aftermarket ones. Why?! And that is Porsche OEM.
-it depends how much meth you are injecting and injection strategy. I use 2x1.2mm (900cc each) aquamist injectors on my 996tt and I dont see heatsoak, without meth and using big 4.5 cores, will get pretty soon to heatsoaking. Also we can simulate gt2rs injection conditions, IAT included as aquamist has possibility to be triggered by external sensors, adding temperature sensor shouldnt be too hard. Engine load can be simulatef by injector duty cycle, rpms by boost etc...So which injectors are you using on your car? Do you know how your meth kit is set up?
And in regards to straight line guys, in my opinion the stress/engine load on the engine for some (mexican) guys running 4-5 races in a row from 50-200+ mph is higher than what we do at the track. So I wouldnt exclude all the info coming from the "dark" side
Jean I am in Dubai now LOL, going to the Autodrome on 2nd of January, I have rented a 458ch this time.. tried mclaren sprint and lotus racecar last year. Looking forward to having some fun as at home is snowing.
Happy New Year everybody!!!
Hi Fadi, I think the logs are pretty conclusive regarding the difference between a straight line run to 200mph and a time attack environment. Even if back to back, straight line events always provide large amount of fresh airflow into the intake and cooling of all hardware components, and an idle time between runs that you don't have on the track.... So the ultimate test for an IC in terms of cooling and recovery time remains the harshest environment the car can be subjected to, which is how Porsche build their engines, keeping safety levels in check.. For the past 10 years I have seen many logs of high speed runs, nothing really compares to circuit racing or time attack or hillclimb at 10,000 feet where air density is such a challenge.
You and Bruce are right, turbos are running out of their efficiency levels, methanol is "supposed" to move the needle back 10-15% on the efficiency map which still keeps you at 68-70% efficiency on the turbos, my checks and balances are timing and AFRs.. timing being pulled is barely existent at these levels and AFRs excellent, we had to pull back the tune several times compared to what my tuner does for his half mile cars, from his own words based on comparable maps and logs, he has never seen a car driven so hard, because 99% of his customers race in straight line or just do track days, not racing. it has taken a lot of back and forth and testing and log scrutiny with the tuner and COBB to get what I needed, I have 68mm compressors btw. Of course also tested different meth setups over the past year.
I doubt the clubsport has larger coolers than the GT2RS street version, it has the exact same engine, if there is any evidence of that, it would be great if you could share. As for the turbos on the GT2RS , all I know is that the compressor (only) has been increased by 10mm vs the 991.2 Turbo, which is the same size turbo as the 991.1, so your data seems a little off. I can bet on this anytime, a stock IC will do better than a 4.5" aftermarket on track, at 24 or 28PSI.
There are many posts on this as you know, I would go Marston (or looks like DO88 are quite similar to stock density) as only options to stock for the track.
I am in Bahrain on the 11-13th if you feel like flying over for a track day!
Happy New Year to all!!
dsddcd (05-06-2020)
