Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   991 Turbo (https://rennlist.com/forums/991-turbo-230/)
-   -   BBi Autosport 2018 991 Turbo EARLY Black Friday Sale (https://rennlist.com/forums/991-turbo/1112351-bbi-autosport-2018-991-turbo-early-black-friday-sale.html)
BBiAutosport 11-16-2018 05:27 PM
1 Attachment(s)
Attachment 1348701
The time has come for the BBi Autosport Black Friday Sale. This year we are putting many BBi Autosport and selected products from our partnered brands on sale at 10% off, and we are starting the sale EARLY today Thursday, November 15 and ends on Monday, November 26.
To place an order, please visit our website or email us at Sales@BBiAutosport.com. We will be closed on Thursday, Nov. 22nd and Friday November 23rd in observance of Thanksgiving but we will be answering emails and orders can also be placed through our website. Orders received during this time will be processed Monday, November 26th. Here are the BBi some upgrades that will be on sale:
BBi Autosport StreetCup II Bolt-In Roll Bar Porsche 991 Turbo
https://c1.staticflickr.com/1/351/18...f98e4777_h.jpg
Features
  • 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
  • TIG welded and utilizes "X" braces on front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide strongest mounting points and maximum protection
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full seat travel to accommodate taller drivers
  • Can be used with stock seatbelts or 6 point harnesses for track use
  • Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
  • OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
  • Finished in satin black powder coat. Other colors available Bolt-in installation requires no drilling and minimal carpet trimming
  • Made in USA
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
https://c2.staticflickr.com/6/5459/3...2389d510_h.jpg
The BBi Autosport race spec seat mounts are a direct bolt in to the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel with no welds to maximize strength and stiffness. All mounts are powder coated with a wrinkle black base and satin black sides.
Features
  • Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
  • Multi way adjustability
  • High strength sliders, mounts to base with 4 bolts per slider
  • Integrated 5 and 6 point sub belt mounting locations
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • No modifications to vehicle or any seat mount components are required for installation
  • Uniquely designed for Porsche vehicles for the best possible fitment
  • Mounts to factory bolt locations with precise factory fitment
  • Fits all major FIA/SFI approved seats up to 17”
  • 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
  • 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
Product Link https://www.bbiautosport.com/product...ry=991.1%20GT3
https://c2.staticflickr.com/6/5588/3...d0e9ab54_h.jpg
https://c2.staticflickr.com/6/5688/3...75cba99d_h.jpg
https://c2.staticflickr.com/6/5639/3...b961c595_h.jpg
Cobb Tuning Porsche 991 Turbo Accessport V3
http://media.cobbtuning.com/catalog/...3_extra_01.jpg
No performance upgrade is complete without a tune to reliably extract as much power as possible while maintaining excellent drivability and consistent results. The Accessport for the 2014 2015 Porsche 911 Turbo and Turbo S is the ONLY handheld flash option. Being the world's best-selling and most flexible ECU upgrade solution, the Accessport V3 comes with Stage 1 and Stage 2 Off The Shelf maps as well as complete custom tuning capabilities for any modification level.
Features
• Power Gains: Stage 1 increases power throughout the low and mid-range with maximum gains of around 60 whp are seen between 3000-4000 RPM. Low-end torque is increased by over 100 ft./lbs! Stage 2 gains 120 ft./lbs down low and nearly 100 hp. at peak.
• Simple Installation: Everything is included for the simple installation you can do in your driveway! Intuitive on-screen instructions identify your exact vehicle, saves stock vehicle data, and displays available OTS maps.
• Change Maps: Store up to 100 maps from our OTS map database or from your favorite COBB tuner and quickly switch between them for any need.
• Vehicle Upgrade Support: As you continue to modify your car, Accessport maps can be used to optimize performance upgrades. Changing the map can be done in less than 1 minute in your driveway.
• In Car Mount: The Accessport can be mounted in vehicle to allow you to monitor the performance data.
• Data Logging: Record multiple data channels simultaneously for in-depth evaluation of engine performance. Stores up to 1 hour of continuous data.
• Gauges: Use your Accessport as a gauge to monitor boost or any other live information, directly from the ECU.
• Trouble Codes: Read engine trouble codes to diagnose issues. Clear them when resolved. Prevent expensive trips to the dealership.
• Full Uninstall: Using the Uninstall option will completely remove our programming from the car’s ECU. It is then able to be re-installed after a dealer visit or on another vehicle.
IPD Porsche 991 Turbo /S Plenum
https://c2.staticflickr.com/6/5753/2...dc3d82e0_h.jpg
IPD 991 Turbo /S High Flow Y Pipe
https://c2.staticflickr.com/6/5778/2...f3b28c5d_h.jpg
IPD 991 Turbo Plenum & Y-Pipe Features:
• Increases horsepower, torque, and boost responsibly optimizing air flow efficiency
• Designed with 3D Modeling & Computational Fluid Dynamics software
• Utilizes diversion splitter and dimpled interior surface eliminate turbulence and increase air flow
• High quality cast aluminum construction
• Direct fit OEM replacement
• Made in USA
BBi Porsche 991 Turbo Performance Intercooler Upgrade Kit
https://c2.staticflickr.com/6/5442/3...3601d69c_h.jpg
Keeping the Porsche 991 Turbos cool, we are ready for track day season with our new BBi Autosport Barcode intercooler upgrade kit. Designed with 3D Modeling & Computational Fluid Dynamics software, this bespoke intercooler features 3D printed and CFD tested end tanks, and offset cores for optimum flow and improved performance.The advanced 3D printing manufacturing process allows us to produce complex design and shapes for optimum flow. This kit is ready for installation (plug & play), using the stock plumbing and shrouds. When engineering, technology, and the right people are fueled by passion, the results are impressive. Stay tuned for more details
Features
  • 3D Printed and CFD Tested End Tanks
  • Offset Cores for Optimum Flow and Improved Performance
  • Designed to Use with OEM Stock Plumbing and Shrouds
  • Compatible with Porsche 991.1 & 991.2 Turbo / S Models
  • Made in USA
https://c1.staticflickr.com/9/8333/2...1f69198c_h.jpg
https://c1.staticflickr.com/9/8885/2...4dc70db0_h.jpg
https://c1.staticflickr.com/9/8083/2...2a9e1357_h.jpg
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
