Module to turn off Auto- Stop ?
Can’t you just use the button on the center console? I only used it one time just to make sure it worked other than that the button has always been pushed disabling it.
http://t-design9.com/memory_module.html
A side note...no need to remove the side bolster as per video...simply carefully pry out the console insert piece that will house the module under it with plastic tool
I'm more curious than anything, but why bother? Turned mine off day one and never had an issue since. Is there a technical reason or risk issue of some sort? Unintended engine turnoff malfunctions reported etc...?
you turned it off once and it never turned on again ? i didn't see anywhere in the manual for it .
Turn the dial to the right...
With the '14 models (at least) the auto-stop module defaults on and the sport setting defaults to off setting when the engine is shut down...this module allows the sport selection to be maintained on if selected on at shut down and auto-stop off always..991.2 I believe are different
