Change Power Steering Fluid - any DIYs on this? Made a big mistake....
I just made a big boo-boo. Yes I'm an idiot. I changed the oil on my new-to-me TTS, and instead of pouring the oil into the oil resevoir....you guessed it, I was in a hurry and started pouring it into where the green cap was - the power steering reservoir. I probably got 1/2 quart in there before I realized. So, to be safe, I'd like to change my power steering fluid.
Has anyone done a video or a write up on how to change the power steering fluid in a 991.1 TTS?
Thanks!
Here's where I put the 1/2 quart of oil:
Doh
Thanks!
Doh
Received 1,149 Likes
If it makes you feel any better, it happens. I goofed once and connected a pressure bleeder to PDCC tank instead of brake fluid tank on my Cayenne. Had to suck the brake fluid out with a syringe to avoid pumping it through the PDCC system because brake fluid would have eaten seals. Can't help with the steering fluid replacement DIY though.
Thanks - that helps. I had never started the engine with the 1/2 quart of oil in there so I knew it would probably be alright. So I ran and picked up a siphon pump and some CHF 11S. 10 minutes later I was back in business.
Not sure what's more embarrassing.....accidentally pouring oil in the power steering reservoir or the dirty engine bay photo. I took care of one, gonna fix the other today.
