Spoiler Loss on Freeway
Has anyone ever gotten this alert below. Was driving home and suddenly it popped up. Spoiler was down and i couldnt even manually get it to go up by pressing the button. when i got home turned the car off and on. Then i could manually press the button and it went up / front spoiler extended. Havent had a chance to go back out and get it back up to speed..
Same problem here. Almost certainly the front spoiler. I've been just deploying them when I get on to decent roads (I have to drive some rough country roads to get there) and leave them deployed. I believe the front spoiler isn't deploying fast enough when you're driving over 70mph with them in sport / normal modes and that's causing the error. The thing that's annoying is that it won't try again and it disables your deployment button.
Had my car at the shop Friday and they ran out of time to fix it ... without keeping the car for days. So I believe they're ordering the pneumatic parts and it's being replaced this week or next (when it comes in).
https://www.sunsetporscheparts.com/o...g2LWdhcw%3D%3D
You likely need that part plus Porsche will have to program it. I had the same problem (worked manually but would get the error at speed and spoilers would retract).
I got this message twice on the same day. The first time it happened I was on a highway and I hit a speed somewhat higher than what's shown in the photo
I manually operated the spoiler and it went away. I drove another 7k+ miles or so after that and it never happened again.
Received 1,542 Likes
Search is your friend. At least 4 previous threads.
Worf - i know there are plenty of threads. My question was specific to the spoiler both front and rear - could be manually operated to go up and down. I just got that error message whilst driving. Given that it was going up and down after the message - i figured what ever motors or mechanisms that make it go up and down were still working. It may be something else.
Update - benefits of Covid and emptier freeways. i just hopped in and got on the fwy up to 85'ish. Saw the spoiler go up - no error message. And then retract automatically when at slower speeds. So i'll keep an eye on it and hopefully its fixed itself. Or just have it checked out when i'm in for a service. Its still under warranty (CPO).
https://rennlist.com/forums/991-turb...ure-stuck.html
List of other spoiler threads:
https://rennlist.com/forums/991-turb...l#post15598939
The key to diagnosis is to completely characterize the problem including *exactly* how to repeat it, write it up, hand the write-up to the technician (not service advisor), and then go over it with the tech.
Sounds like the same problem I had. See #11:
In the absence of error codes and in the presence of ambiguous error codes, dealer techs don't, in general, get paid to spend their time figuring out how to trigger failure modes like this. It's generally a non-tech given instructions to drive the car and attempt to characterize the failure enough to describe it to the tech. Thus, why the quickest, best out come is to be able to explain to the tech exactly what's happening and what isn't happening.
In my case it was the pressure sensor that failed. It's available separately from the pump (when I checked) but Porsche, it seems, prefers to warranty the whole pump rather than pay a tech to disassemble/reassemble the pump (I suspect due to risk of follow-on warranty service if the pump isn't correctly reassembled.)
I suspect that 10 years hence Active Aero Delete may become a popular DIY task.
I’m having the exact same problem...intermittently losing spoiler...sometimes the warning pops up when the pooled isn’t eve deployed..seems to happen most when accelerating through 80 mph.
Took it to Porsche Irvine, got very frustrated because without finding a hole or signs of damage to the from spoiler airbag they gave me an invoice for $5k to replace everything...when I asked where the leak was they admitted that after having my car for 4 days all they had done was pull codes.
It can’t be an leak though because it’s intermittent....that would defy physics.
