AIM Performance/ES Motor Built 991
The cat is out of the bag. After being frustrated with my meth gauge failing at the last event and relying on lots of meth for fueling, I asked the boys at AIM Performance to solve that issue.
So 90 days ago I gave them the OK to proceed, and to go ahead and build the motor, too. ES1000 package here we come. 11 days ago the car wasn't even running. Now it's doing the 60-130 mph in 3.6 secs and trapping 196mph in the 1/2 mile at Shift S3ctor at a shake-out, low-to-moderate-boost test outing.
Major props to Ryan Kube and Joe Santos from AIM Performance and Emre Levent of ES Motor. Still can't believe what you've done in 90 days, let alone the last 11.
Also congratulations to Ryan Kube for setting the new World Six-speed Porsche Record with a 203mph pass. Simply awesome.
Lastly, congratulations to TopSpeed who set the 991 World Record 1/2 mile today at 201+.
-Dave
-Dave
What are your goals for this car? Are you aiming for 200+ in the 1/2? What do you think its going to take to get your last 4mph to crack 200?
Any idea what kind of boost pressure you were running on your 196 run?
I saw an instagram post by TopSpeed, pretty impressive they were able to go 200+.
Yes, TopSpeed has done a great job with their car and they set the World Record!
Thats very impressive.. I assume you are running a 4.0 and Syvecs.. How comfortable are you with long term reliability, I somewhat always worry about aftermarket ECUs and sensor protection in a changing weather/pressure/fuel environment. The reason you get all this power is because you are pushing the envelop on the AFRs, timing and boost using larger non-VTG turbos and additional injection, which the Porsche ECU wouldn't allow you to do except if you use one of few people in Germany who can do it.
You've got a very nice stable of cars there!
And thanks
