Mass members with after market cats
Hi:
I am looking for input on anyone who has an aftermarket exhaust in MA, my concern is passing the smog sniff test during the inspection. The state seems to be cracking down on everything not stock. I am looking at doing a header/cat/exhaust system and don't want to fail the "sticker" Anyone out there with a 991 and either 100 or 200 cel cats?
Received 1,542 Likes
Hi:
MA hasn’t done exhaust sniff tests in at least a decade. As long as you:
- have a front plate
- there are *NO* ODB-II engine or emissions codes
- your exhaust isn’t obviously a lot louder at idle
... no one will care.
If you get unlucky and a visual inspection is performed as required, then, as long as all the above apply and there’s no obvious absence of cats...
I'll go with the 'at arms length'. Every time I brought a car in, I am required to leave it outside and sit in the waiting area. I have been free for 40 years and am lucky enough to have the "green plates" so we don't need to worry about a Ft plate. Thank you for the info.
Not in MA, but PA, as said they plug the car into the OBDII port, no codes no problem. I have headers, 100 cell cats with Kline exhaust, no problems with inspection here, I have a 991.2 tts
FYI, You are only ‘required’ to not interfere with the person performing the actual inspection. Most shops prefer to prevent Muggles from seeing how the sausage is made.
I have 2 "sets" of green plates, they have always gone from one car to the next. The 991 plates were on a ZR1 until March 2018 and the other set was o na Lexus then on a Macan in 2016. We never had a problem, and never did anything special
Interesting. I sure wish I still had a green plate or two. How often do you need to repaint the numbers?
Basic Sponsor
Hi:
Depending on the year of your 991 Turbo, you may have a different design. Take a look at the video below detailing our designs and feel free to reach out regarding forum pricing!
