DIY TTS Oil Change & tire pressure
Received 1,543 Likes
So, any 991 oil change instructions you find will show you the way.
Drain plug torque is 50 Nm. Filter cover is 25 Nm.
These are 991.1 figures.
No. Part-load comfort pressure: 31/36
See these threads:
https://rennlist.com/forums/991/1057...-purposes.html
https://rennlist.com/forums/991/1060...-question.html
- DON'T cross thread the oil filter like me!!!
- Get the parts from dealership
- When using a break bar/wrench, make sure one hand on the axis of turning, so nothing will be damaged.
- idle the car for a bit before draining the oil
For tire pressure, i go 31/36 at 20 Celsius.
