Change brake pads only? Steel brake no PCCB
If the rotors are still 'good' within Porsche's specification, is it ok to change the pads only? If its possible, is re-surfacing the rotors necessary?
Yes and No.
Lots of the track rat guys change pads for the track event then change back to street pads.
Received 1,543 Likes
Me three: totally ok to replace pads on one or more axles without changing or ‘surfacing’ the rotors.
However, DO be sure to follow the recommended bedding-in procedure for the new pads.
