Sponsored by: Road Spy
Code reader clear CEL?
Old 11-08-2017, 10:47 AM
PPFANBOY
PPFANBOY's Avatar
Default Code reader clear CEL?
Hi all,
My current exhaust setup sometimes results in CEL on my 991.2. It is sporadic and I can't really explain it.
Can anyone suggest an easy to use code reader I can use to delete the CEL when it does pop up? (I find it very annoying and until a tune is available, I need an interim solution).
Cheers!
Old 11-08-2017, 04:24 PM
JW1
JW1's Avatar
Are you using adapters on your bypass for the rear most O2 sensors? If so, are you also using the smallest plugs within those adapters?
Old 11-08-2017, 08:58 PM
PPFANBOY
PPFANBOY's Avatar
Need to check! I'm not sure.
Old 11-08-2017, 09:03 PM
PPFANBOY
PPFANBOY's Avatar
Thanks for clear pics. Will check with my tuner.
Old 11-08-2017, 10:21 PM
JW1
JW1's Avatar
For people running catless, you basically don't even need the rear most O2 sensors to be exposed to the exhaust gases. They are just there to tell your ecu that your emission system is working properly and that the cats are scrubbing the gases sufficiently before it exits into the atmosphere. That's why you use the insert with the smallest hole in the adapters. You could even plug up those adapters so no gases goes to the sensors and you will never get a CEL for being catless again.
Old 11-09-2017, 11:07 AM
DIM4
DIM4's Avatar
why not just tune it and do cell delete?
Old 11-09-2017, 12:20 PM
PPFANBOY
PPFANBOY's Avatar
991.2 turbo. No tune.
Old 11-09-2017, 12:59 PM
DIM4
DIM4's Avatar
991.2 turbo can be ECU tuned no problem. It's an SDI21.3 ecu from Siemens
Old 11-10-2017, 12:50 AM
PPFANBOY
PPFANBOY's Avatar
Who is tuning it?
I think Giac are the only ones ATM, that is for the Turbo S though.
Old 01-18-2018, 01:29 AM
C4SxM5
C4SxM5's Avatar
Any solutions? I had a mini orange cel reader/eraser but it isn’t clearing my cel either.
Im running catless with the smallest adapter and still got a cell after parking the car for a few days.
Old 01-18-2018, 10:10 AM
BOOSTED TTS
BOOSTED TTS's Avatar
Who is tuning it?
GIAC and By Design.
Manuel
Old 01-18-2018, 11:00 AM
JW1
JW1's Avatar
You can just plug up the smallest adapter so that no gases get to the farthest O2 sensor. That sensor is not needed anyways for your engine's AFR calculations. It's just for emissions which by you going catless, you are not worrying about anyways.
Which adapters are you using? And are you sure you secured the small ring clamp properly to secure the insert?
Old 10-27-2018, 11:26 PM
aft86
aft86's Avatar
Will plugging them completely fix the problem? Don't the sensors need to breathe? I am using these Vibrant spacers on a catless exhaust too but I am still getting the CEL for both banks.
Quick Reply: Code reader clear CEL?
