Sponsored by: Road Spy
Running problems
Old 06-07-2018, 04:12 PM
Jim M.
Jim M.'s Avatar
Default Running problems
About a week ago I started having 4 different warning messages. (see pics) Car is under warranty so I made an appointment with the dealer. Outcome was they found a bad coil on the #4 cylinder. The technician swapped the coil with the #3 coil, drove the car and confirmed the problem moved to the #3 cylinder. He then reinstalled the coils to their correct location and replaced the #4 coil with a new unit. I read these forums all the time, even well before I bought my TTS. Coil failures appear to be very uncommon. Just wanted to pass on the info if anyone has similar problems.
Old 06-07-2018, 06:24 PM
NiteJav
NiteJav's Avatar
That's crazy that a coil pack failure could cause that laundry list of failures.
Old 06-08-2018, 01:49 AM
Papa Fittig
Papa Fittig's Avatar
Thanks for sharing. Good they found the root cause.
Old 06-08-2018, 07:02 AM
hcvone
hcvone's Avatar
I had a 5.9 grand Cherokee, when one of the coils failed it gave codes for radio failure among about 10 others nothing having to do with the coil. Thanks for the info
Quick Reply: Running problems
