Front and rear spoiler question ?
Hi guys, a question regarding the front and rear spoiler,
I'm in the last stages of buying a 2014 TT. I test drive it yesterday and the front and rear spoilers didn't operate as they should.
Should both spoilers retract tract when I press sport & Sport plus ? I tried doing that, the car was in P and nothing happened. I would have to press on the spoiler botton for a few seconds until they retract.
Car was fully checked by dealer with no problems whatsoever. No failure messages or warnings in the dash.
Any input would be helpful.
Thanks !
Thanks !
Hi,
In parking mode they will not extend/retract until the car drives off unless you hold the spoiler button and then you will see them extend/retract. This is normal.
Manuel
Manuel
Received 1,542 Likes
Manual operation of the spoilers is they same in all regimes: you push and hold the button until the MFD tells you otherwise.
Once you are moving(around 10-15km/h, one press of the button or sport plus mode will extend the spoiler.
If you are standing still, you have to press and hold the button.
