This car is so much fun :)
Yes, pretty fortunate to have good GT3 weather in San Diego. There are definitely some great roads here which I have covered in articles for Total 911 mag but there many in dire need of repair. As we all probably do, some drives have to be pre planned to ensure the roads are not too bad. All in all though, the roads are pretty good and great fun in the hills of San Diego.
I'm enjoying winter driving, as I normally do with whatever car I buy. I do 90% of my road pleasure driving during the winter, once it's warmer the only driving I generally do is errands or to the track.
I don't much enjoy warm weather driving on the back roads as there is too much traffic.
I always run winter rubber from about Thanksgiving until Good Friday.
Let's say it's midday and 32F outside, but it's sunny and the roads are warmed up and dry from the sun and a check of the tires shows the psi's have risen appropriately from when you started the car. Still tricky driving?
Let me guess, it's midday, sunny and 32F in Philly right now
It was something to do with the compound degrading from memory. I don't think this would be an issue if it's a drive and back into the garage, but would avoid parking it outside for long periods with them on to play it safe.
Thank Haku, I'm ok, the car is ok but my feelings are hurt. I pushed the car a little too hard and now I know not to try that stunt again in the cold. Below 40 is probably a good flash point where you notice it. Car and tire still grips like hell but its not superman anymore under 40 degrees.
I know Michelin used to recommend not storing the tires below 40F and not driving below 45F on the old MPSC. I'm not sure if that's still the case with the MPSC2 as mine are off the car. It was something to do with the compound degrading from memory. I don't think this would be an issue if it's a drive and back into the garage, but would avoid parking it outside for long periods with them on to play it safe.
So if this is the case, cars which are stored for the winter months in the colder climates with below freezing temps, is the recommended option to remove and store tires indoors? My garage is attached to the house and insulated but not heated. On the coldest of days it generally does not get below freezing inside but I would think below 40 F.
